Electrical Issue
Old Nov 13, 2017 | 04:14 AM
parsapour's Avatar
Icon5 Electrical Issue
My 1991 EXI M/T Honda accord doing very well in all aspects, but when I drive to the humid province, Horn doesn't work And Cruise Control Dash indicator light goes off and its function turns off. then once I return back home in the dry climate Horn & Cruise Control back to function. would like to know what may cause such case? what procedure/measure should I take to diagnose the issue and how to approach to remedy, I tried to pursue the ground cables under Battery compartment and elsewhere in the engine bay, they look pretty fixed. but all I made could not solve it. thanks for readings & your tech. comments.
Best regards.
Old Nov 13, 2017 | 04:21 PM
tamboo's Avatar
10 Year Member
Default Re: Electrical Issue
i had a similar issue, turned out the lower cable reel connection was loose.
if all connections seem good i'd test each cable reel terminal for continuity.
only about $20 to replace with a used unit from ebay.
Old Nov 14, 2017 | 04:30 AM
parsapour's Avatar
Icon2 Re: Electrical Issue
Dear Tamboo,
Thanks for your inputs, Can you please clarify where to access the lower cable reel connection?
Thanks a lot.
B/R.
DOHCter VTEC
Jan 21, 2008 09:03 PM
allmotorek8
Feb 21, 2006 02:44 PM
stevescivic
Aug 11, 2005 06:28 PM
jhota
Nov 20, 2004 12:15 AM
elnoyl
Apr 26, 2003 07:01 PM
