Ecu code 67 Catalyst system efficiency below threshold, what does it mean???
Old Jun 25, 2006 | 12:15 PM
chomorro's Avatar
Default Ecu code 67 Catalyst system efficiency below threshold, what does it mean???
I just got this code a few days ago, 98 accord LX 5spd vtec. How do i fix this problem?? i passed smog with flying colors about a week ago, way below the higher standard CA emissions requirements, so i assume my cat is working fine.
Old Jun 25, 2006 | 01:45 PM
Chiovnidca's Avatar
Default Re: Ecu code 67 Catalyst system efficiency below threshold, what does it mean??? (chomorro)
Needs a new cat.
Old Jun 25, 2006 | 02:18 PM
YeuEmMaiMai's Avatar
could also be seconday O2 sensor. You will need a Diag machine and a Infrared temp meter to determine for sure.
I hope that it is your secondary o2 sensor since it is a LOT CHEAPER than a new cat.
if you recently replaced either your cat or o2 sensor with non Honda ones, that maye cause this issue as well.
Old Jun 25, 2006 | 02:38 PM
Chiovnidca's Avatar
Default Re: Ecu code 67 Catalyst system efficiency below threshold, what does it mean??? (YeuEmMaiMai)
A bad o2 sensor causing a catalyst code is a longshot. Especially on a 98 accord.
Old Jun 25, 2006 | 02:48 PM
chomorro's Avatar
Default Re: Ecu code 67 Catalyst system efficiency below threshold, what does it mean??? (Chiovnidca)
well i just bought the car so im not sure if the 02 sensors or the cat have been replaced. But if it was the o2 sensor wouldnt thier be other symptoms like really bad mpg hesitation and stuttering??? And why would i pass smog no problem?? Thanks for the help
Old Jun 25, 2006 | 03:37 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chomorro &raquo;</TD></TR><TR><TD CLASS="quote"> And why would i pass smog no problem?? Thanks for the help</TD></TR></TABLE>
The ecu can detect the efficiency of the cat decreasing before it stops working all together. When it drops to a certain level it throws the code. (and cel)
Old Jun 25, 2006 | 11:20 PM
chomorro's Avatar
Will a random tech high flow cat still throw this code?????
Old Jun 26, 2006 | 10:24 AM
chomorro's Avatar
Ok 500 bucks for an oem cat, someone please tell me they are running an aftermarket one and it doesnt throw a code.
2stroke1971
Aug 9, 2016 03:33 PM
Integra_Boi
Apr 15, 2016 04:22 AM
janek
Nov 3, 2008 02:25 AM
chirp3rd
May 1, 2005 07:22 PM
brcivic411
Apr 14, 2004 11:24 AM
