ECU Code
Old Jan 10, 2005 | 11:32 AM
dirtracer's Avatar
Default ECU Code
I've had a problem after a swap I thought was the Main relay. i had no fuel in main rail checked all plugins now i got fuel the relay buzzed then it stopped; turned overbut only about 3 timesand relay started to buzz again. Checked the ECU and it has a solid light.I'm taking for granted that you have to have the ign. on. Anyway I could use some help. T.I.A.
Old Jan 10, 2005 | 01:02 PM
.bagged's Avatar
Default Re: ECU Code (dirtracer)
You are going to have to check the code.
CHECKING THE ECU CODES
If your CEL has illuminated, it is more helpful to know WHY it has lit up instead of just guessing at the problem... How do you find out what the error is? Well you will need a short peice of wire or a paperclip.
On the passenger side of your car, under the dash beneath the glove box, you will find a green cover above the kickpanel that houses a blue connector that has two wires.
That you need to do is turn the ignition off, and using the piece of wire or paperclip, jump the blue connector so that you connect the two wires together. Basically stick one end of the paperclip or peice of wire into one prong on the connector and stick the other end of the paperclip or wire into the other prong.
Once you have done this, turn the key to the IGN position and watch your CEL light. It will illuminate in a series of flashes.
You will notice that there will be LONG flashes and SHORT flashes. All of the ECU trouble codes are two-digits. LONG flashes determine the TENS digit by the number of times it flashes, and SHORT flashes determine the ONES digit by the number of times it flashes.
ie. LONG-LONG-LONG-SHORT-SHORT-SHORT-SHORT-PAUSE
is the trouble code: 34
3 LONG flashes followed by 4 short flashes, then a long pause. If that is the only code the ECU is throwing, then the code will simply repeat until you remove the key. If, however there are more than one ECU error code, then you will see a different series of flashes followed by the long pause. Once all the ECU codes have been displayed, they will continuously cycle until you remove the key.
ie. LONG-LONG-SHORT-PAUSE-LONG-LONG-LONG-LONG-SHORT-SHORT-SHORT-PAUSE
is the trouble code: 21 and 43
Once you have determined the codes, you can simply remove the paperclip or wire from the connector and replace it back in the green housing.
ECU Codes
SolScifen
Sep 30, 2012 11:29 AM
teknohatchie91
Apr 1, 2009 11:51 PM
Speedyjay
Apr 28, 2007 05:29 PM
claysold
Sep 12, 2005 07:57 PM
ceLtic*
Apr 15, 2005 02:38 PM
