duplicolor spray Satin Silver?????????
ok just found out that they dont make satin silver in a duplicolor spray
does anyone know what color silver i could use i have to touch up some spots on my mothers front bumper and i dont wanna spenc a shitload of cash
* B A N N E D *
Re: duplicolor spray Satin Silver????????? (DeDonDeRosa)
if you try to use that over-the- counter spray paint from your local auto parts store you're gonna make that car look worse than it does now....what you need to do is go to a body shop have them get the color code and mix up a little bit of touch up paint for you....it wont cost you that much and it will be pretty much a perfect match.
Re: duplicolor spray Satin Silver????????? (EASY101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EASY101 »</TD></TR><TR><TD CLASS="quote">if you try to use that over-the- counter spray paint from your local auto parts store you're gonna make that car look worse than it does now....what you need to do is go to a body shop have them get the color code and mix up a little bit of touch up paint for you....it wont cost you that much and it will be pretty much a perfect match.</TD></TR></TABLE>
I'm not sure his Mom's will care too much. Certain auto parts stores can mix you up some paint by code. If you do it right you can get decent results. Enough that most women wouldn't notice.
Good luck
Good luck
