Door/ignition/headlight reminder (beep) not working on 1995 Accord
Old 02-04-2014, 10:38 AM
Alex E's Avatar
Default Door/ignition/headlight reminder (beep) not working on 1995 Accord
I have a 1995 EX coupe and it never beeps at me for anything (could be a blessing) but I'd like to fix it. Any suggestions on how to fix it? I'm guessing it's possibly just a fuse or switch.
Old 02-04-2014, 12:35 PM
95accordian's Avatar
Default Re: Door/ignition/headlight reminder (beep) not working on 1995 Accord
it most liking is a fuse possible relay, but I would go through them all checking which it is. the most possible worst it can be is crossed wire, or a ground came loose or corroded.
Old 02-04-2014, 01:19 PM
Alex E's Avatar
Where do I look and how do I check to see if the fuse or relay is bad? Newbie here.
Old 02-04-2014, 10:21 PM
MM Gruppe B
MAD_MIKE's Avatar
I don't recall where the warning buzzer is, but if your ignition tumbler/switch was ever repaired/replaced it may be that the wiring for the warning buzzer was never reconnected. Remove the plastic cowling for the steering column and inspect the wiring.
Jesseatt
Honda Civic (2001 - 2005)
04-25-2019 05:06 AM
tinker222
03-29-2015 09:03 AM
lakerschamp2000
01-11-2010 08:41 AM
jdmep3
07-31-2005 04:30 AM
Quick Reply: Door/ignition/headlight reminder (beep) not working on 1995 Accord
