Disc Conversion Help
Old Jun 3, 2004 | 05:56 PM
Accord_Kid's Avatar
Default Disc Conversion Help
Correct me if i'm wrong, i've recently purchased the necessary parts to do a rear disc conversion on 96 LX accord and am now looking for a prop valve. I called my buddy and he explained to me that i CAN use the prop valve from the 94-97 EX's even though its part of the ABS. Is this true that i can use the EX prop valves without the abs modulator without having any problems? he also emphasized that using the 90-93 teg prop valve will absolutely not bolt on.
TIA everybody.
Old Jun 3, 2004 | 06:44 PM
Accord_Kid's Avatar
Default Re: Disc Conversion Help (Accord_Kid)
anybody with any experience?
Old Jun 3, 2004 | 09:32 PM
Accord_Kid's Avatar
one up
Old Jun 4, 2004 | 04:58 AM
The_Todd's Avatar
Farts in the shower
This article will provide some needed material:
http://www.accordinglydone.com...=2056
and this 1 is also upgrading the entire system with legend brakes, not only cheaper but with the same stopping power as the "big brake kits"
Also if you want to upgrade to 5 lug you can use 97 or 98 and + 5 lug hubs from other accords, cool thing about our cars is that most is interchangeable.
Old Jun 4, 2004 | 05:51 AM
SearchBeforeUPost!'s Avatar
https://honda-tech.com/zerothread?id=825404
Willie (v4lu3s) has actually used the teg prop valve. According to his response in the post above, it works fine. That is my rear disc swap article on the link above, so I can answer any questions you may have.
Old Jun 4, 2004 | 01:58 PM
Accord_Kid's Avatar
Default Re: Disc Conversion Help (SearchBeforeUPost!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SearchBeforeUPost! &raquo;</TD></TR><TR><TD CLASS="quote">Willie (v4lu3s) has actually used the teg prop valve. According to his response in the post above, it works fine. That is my rear disc swap article on the link above, so I can answer any questions you may have. </TD></TR></TABLE>
isn't it true that with the 90-93 prop valves, you need to fabricate it a little? from what i heard it doesn't even go on correctly nor does it bolt on.
Old Jun 5, 2004 | 04:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">bolt it on and go.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=879660
Old Jun 10, 2004 | 12:52 PM
Accord_Kid's Avatar
thanx man
91integra91
24
May 15, 2010 02:56 PM
NGUSPEED
Mar 5, 2008 01:23 PM
SuShiBoiiii
Jun 20, 2005 08:47 AM
ls95hatch
Jun 28, 2004 11:36 PM
akkording
Jul 2, 2002 07:08 AM
