Decode please.
Old Nov 13, 2005 | 11:47 AM
killah3084's Avatar
Default Decode please.
I did some research on unstable idle, but the term that are used i don't understand. Somebody decode them please and let me know where those parts are located.
EGR ports - What does EGR stand for/where is it/how do i clean them?
PVC Valve - What/where again/how do i replace it?
Fuel Filter - where/ how do i replace it?
Old Nov 13, 2005 | 12:21 PM
NAiL05's Avatar
Default Re: Decode please. (killah3084)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killah3084 &raquo;</TD></TR><TR><TD CLASS="quote">I did some research on unstable idle, but the term that are used i don't understand. Somebody decode them please and let me know where those parts are located.
Fuel Filter - where/ how do i replace it?</TD></TR></TABLE>
Exhaust Gas Recirculation - Valve should be located on your IM and same as the ports. They are capped off by lil circular caps.
IM thinking you mean PCV not PVC (Polyvinyl Chloride). Positive crankcase Ventilation - It should be on your valve cover.
Fuel Filter should be located under the Intake manifold, Passenger side Firewall. There might be a black box blocking the way above it but the fuel filter will be right underneath.
Old Nov 13, 2005 | 02:33 PM
killah3084's Avatar
thank you. How do i know if pcv valve is bad? Where are EGR ports exacxtly on Intake Manifold?
Old Nov 16, 2005 | 09:12 PM
NAiL05's Avatar
Default Re: (killah3084)
EGR Ports are on the Intake manifold. Kinda hard to explain but they are the circular markings on your IM. You can pull your PCV off and shake it. If you hear it moving inside then it should be good.
Old Nov 16, 2005 | 09:27 PM
iam7head's Avatar
Default Re: (NAiL05)
EGR...ar...it's a round thing that have a clip harness attached to it, it's on top of the IM and there should be a green tag on it(at least on newer accord)
pcv is located right on top of the Valve over it's a 90degree bent plastic "L"
fuel filter, it depends on what generation of accord, early accord have a in hood filter, 6th gen have a fuel filter in the gas tank
Old Nov 17, 2005 | 08:30 AM
Thunder Cat's Avatar
for EGR port cleaning/locating here is a link. make sure you match your specific model though. http://www.cb7tuner.com/vbb/showthread.php?t=2495
and for the PCV valve replacements here is a link. http://www.cb7tuner.com/vbb/showthread.php?t=10057
hope that helps out.
preludequestion
Oct 19, 2009 11:41 AM
HybridBB6
Jun 24, 2007 02:36 PM
dj626
May 4, 2005 10:32 AM
JDM_SOHC
May 3, 2005 04:40 AM
91'CRX
18
Mar 23, 2005 05:10 AM
