cracked temperature knobs solution
Old Oct 28, 2005 | 05:24 PM
BLKFLSH's Avatar
Default cracked temperature ***** solution
I noticed after buying two new temperature control *****. When I turned the **** I would start feeling a lot of resistance when the **** was about halfway around. So when I felt the tension I would stop turning it, let it sit for a few seconds, then turn it the rest of the way around. It did'nt take long for it to loosen up and turn easy again. I thought that was easier than trying to lube the cable, which may or may not work.
Old Oct 28, 2005 | 07:30 PM
deserthonda's Avatar
Default Re: cracked temperature ***** solution (BLKFLSH)
very good. ........do it that way or very slow and even all the way through ,,,,,,the reason those cable get stiff is because when people turn the **** fast the inner cable kinks and bends in the outer shell ,,once that happens it will be harder to turn the **** ..
Old Oct 28, 2005 | 08:48 PM
BLKFLSH's Avatar
Default Re: cracked temperature ***** solution (deserthonda)
People want to just spin the **** around real fast. You can crack a lot of ***** that way
Old Oct 28, 2005 | 09:35 PM
cd5_2NR's Avatar
glue...
dansaleen_04
Oct 6, 2010 02:36 PM
mxl36o
Feb 20, 2009 04:15 AM
topp_dawg_g
Apr 9, 2008 05:53 PM
98vtec
Dec 21, 2006 01:57 PM
mpxs20
Mar 30, 2006 02:16 PM
