COMPRPESSION TEST QUESTION
Old Apr 10, 2005 | 01:10 PM
lv6l's Avatar
Default COMPRPESSION TEST QUESTION
i would like to know in order to do a comperssion test on a automactic car, do you do the same thing for manual like remove the spark plug and wires and just crank the engine? or is there a certain electical plug i have to remove for automactics. thanks.
Old Apr 10, 2005 | 01:26 PM
notoriousB's Avatar
Default Re: COMPRPESSION TEST QUESTION (lv6l)
same way - just pull your fuel pump fuse, pull your plugs, install tester, press gas all the way to the floor and crank it.
Old Apr 10, 2005 | 01:44 PM
lv6l's Avatar
oh thanks.
would anyone know the compression points for a 3.0 litters v6?
Old Apr 10, 2005 | 03:17 PM
philadd's Avatar
Default Re: (lv6l)
standard - 178psi
minimum - 135psi
max variation between cylinders - 28psi
Old Apr 10, 2005 | 05:37 PM
iam7head's Avatar
Default Re: (philadd)
anything more than 10percent change you'll have a problem
B18CivicHatch
Aug 24, 2007 12:11 AM
standbackimapro
May 3, 2006 10:18 PM
Traction
Apr 6, 2004 06:11 PM
5thgenlude101
Sep 17, 2003 02:40 AM
CNSK
Mar 29, 2003 12:45 PM
