Check engine light
Old Dec 11, 2006 | 08:55 AM
skiptomylou's Avatar
Default Check engine light
I have a 94 accord lx and the check engine light is on.
Is there anywhere I can go that will read it for free?
Old Dec 11, 2006 | 08:56 AM
TheMuffinMan's Avatar
He knows where you live!
Advanced Auto / NAPA type of stores should do it for free. Otherwise I think it's in the Accord FAQ you can use like an LED to get the code
Old Dec 11, 2006 | 09:14 AM
hondadude's Avatar
Default Re: Check engine light (skiptomylou)
You can read the code for free; at the top of the passenger side kick panel there is a BLUE 2 pin connector; jumper that with a wire and turn on the key to get the 'flash' code.
Repost with your code
Old Dec 11, 2006 | 09:42 AM
gulfview's Avatar
Default Re: Check engine light (hondadude)
AutoZone also offers a free reading service.
Old Dec 11, 2006 | 09:43 AM
gulfview's Avatar
AutoZone also offers a free code reading service.
Old Dec 11, 2006 | 09:46 AM
great, i'll try all that later today. Thanks.
Old Dec 11, 2006 | 10:28 AM
Persian Virgin's Avatar
Default Re: (skiptomylou)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skiptomylou &raquo;</TD></TR><TR><TD CLASS="quote">great, i'll try all that later today. Thanks.</TD></TR></TABLE>
Old Dec 11, 2006 | 12:41 PM
c0ke's Avatar
Default Re: (Shantia R xv)
I did the jumper thing and I got
6 long flashes then 3 short flashes.
My best guess is a o2 sensor.
Old Dec 11, 2006 | 12:42 PM
ninja 6's Avatar
Default Re: (c0ke)
It's not really free at autozone...
you pay to buy it to use it once and they buy it back...
But it does allow you to clear the code
Old Dec 11, 2006 | 12:45 PM
philadd's Avatar
Default Re: (ap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ap &raquo;</TD></TR><TR><TD CLASS="quote">It's not really free at autozone...
But it does allow you to clear the code</TD></TR></TABLE>
Que?
They come out with their scan tool, plug it in, check the code, tell you what you want to know, unplug it, and walk back in. It's one of their free "services". You don't need to rent and return the scan tool.
Old Dec 11, 2006 | 03:25 PM
Default Re: (philadd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd &raquo;</TD></TR><TR><TD CLASS="quote">
Que?
They come out with their scan tool, plug it in, check the code, tell you what you want to know, unplug it, and walk back in. It's one of their free "services". You don't need to rent and return the scan tool.</TD></TR></TABLE>
Correct
Old Dec 11, 2006 | 04:51 PM
BLK Accord EX 97's Avatar
Hi My 94 accord Lx light is also on. Im aware of how you can check it yourself by jump wiring the ecu unit. But I tried that it came up with a code 14 or 15 which is the idle air control valve or 15 being a ignition problem ( which it could be my ignition coil). I took it to a mechanic and had the idle air control valve replaced with a junk yard part. But the mechanic said he couldnt get the light off. The mechanic said put injector cleaner in the car because of it sitting for awhile and it sould take the light off. I was wondering where can I take the car to get the cars code pulled proffessionally because I took it to autozone and they said they wont do it on a 94 accord. Has anybody tried NAPA before.
Old Dec 12, 2006 | 05:25 AM
Default Re: (BLK Accord EX 97)
bump
Old Dec 12, 2006 | 12:27 PM
honda_kid42's Avatar
there is no reason auto zone wouldnt do it unless it is ODB1...there is no NAPA around here so i wouldnt know about them???
Old Dec 12, 2006 | 05:06 PM
JimBlake's Avatar
Default Re: (honda_kid42)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_kid42 &raquo;</TD></TR><TR><TD CLASS="quote">there is no reason auto zone wouldnt do it unless it is ODB1...there is no NAPA around here so i wouldnt know about them???</TD></TR></TABLE>Exactly. Read the original post; he's got a '94...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c0ke &raquo;</TD></TR><TR><TD CLASS="quote">
My best guess is a o2 sensor. </TD></TR></TABLE>Or loose wiring to that sensor. (Code 63 refers to the rear O2 sensor, in the back half of the catalytic converter.)
DirtyDade
Feb 10, 2019 07:55 PM
Climbtrees
Jul 26, 2012 01:32 PM
FTW_Accord94
Nov 29, 2008 12:15 AM
Delano5050
Aug 5, 2008 09:12 AM
krytoi
Feb 12, 2007 01:54 PM
