Charging System Problem
Old Nov 24, 2005 | 06:53 PM
Rolly34's Avatar
Default Charging System Problem
I have a 1993 accord with a 2.2L, the car would not charge so i replaced the alternator, and it didnt help, so i had the new alternator tested and it was fine but the car with not charge, i looked for fuses but i couldnt find any. are there any charging system fuses and if so where are they? or is the problem else where?
Old Nov 24, 2005 | 07:57 PM
iam7head's Avatar
Default Re: Charging System Problem (Rolly34)
what about the lead grid in your battery? are they good?
how long you have it?
is it always being braced down against vibration?
ever suck the battery dry?
Old Nov 24, 2005 | 09:28 PM
Schmitey's Avatar
Default Re: Charging System Problem (iam7head)
define the car will not charge...may sound stupid but have you checked the battery? Check your battery cables/terminals too!
There should be an alternator (40A)and battery (100A)fuse in the huge fusebox under the hood, really can't miss it.
Back before I knew anything about cars I wasted a few hours helping my stupid friend replace his alternator only to find out it was a blown fuse...that sounds like a likely culprit. Are you running a sound system or anything that puts a load on the system?
hondastrtracr
16
Jan 27, 2008 09:16 PM
duyfash0
Dec 16, 2006 01:10 PM
ScottC
May 10, 2006 11:31 AM
ID_ten_T
Nov 2, 2004 11:24 PM
MachAF
Dec 7, 2003 09:36 PM
