Changing Transmission Fluid
#26
Re: (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">
i agree. don't flush the trans.</TD></TR></TABLE>
#29
Re: (Mitsu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mitsu »</TD></TR><TR><TD CLASS="quote">it's a 95 accord, I thought there was an accessable drain plug?</TD></TR></TABLE>
there is, its on the passenger side and has a slot to fit a 3/8 drive ratchet into to loosen it.
#30
Re: (pos_cd5)
I always hear mechanics that say that if a transmission is going, if you put in fresh tranny fluid, it goes faster than with the old one in it. With that said, the drain and refill might be the way to go. The drain and refill is what the service manual from honda recommends.
#31
Re: (pos_cd5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pos_cd5 »</TD></TR><TR><TD CLASS="quote">
there is, its on the passenger side and has a slot to fit a 3/8 drive ratchet into to loosen it.</TD></TR></TABLE>
ok thats what i thought, thanks.
#32
Re: (Mitsu)
for a 99 v6 accord is the drain plug a 3/8 drive too or something different? and if you guys have a pic of it that would be even better. thank
#33
Re: Changing Transmission Fluid (bemused)
When I learned to tie my shoelaces I didn't make fools of people that couldn't tie their shoelaces. [Albert Einstien]
There is a drain plug on the lower part of the trans that has a 3/8" square hole in it.
Remove that plug with a 3/8" drive ratchet, clean off the second gear clutch pak material from the magnet attached to the drain plug. Reinstall the drain plug then put in 3 qts of genuine honda trans fluid.
No doubt some simpleton will now jump in and SHOUT the 'book' calls for 2.8 qts of trans fluid, but I've been doing this for over 22 years and have NEVER seen a honda trans hurt by having .2 qts extra fluid in it.
#34
can anyone tell me what size washer i should get to replace the old one when i do an ATF change? 1990 Accord EXR. and does the size change depending on the color of the car. mine is white.
#36
He knows where you live!
Yes you want to use clean fluid each time. Why would you put dirty/used fluid in there to flush out the old fluid? The point of doing it is to free up any fluid/gunk that may have not come out the first time around.
#37
i recommend automatic trans fluid drain nd refills to my customers with hondas every 15,000 because thats what i was told by acouple honda techs. also DONT use ANYTHING BUT GENUINE HONDA TRANS FLUID!!! even if it says its ok for use in hondas, dont use it unless its from honda. u will burn out the trans.
#38
I have a 99 civic ex. I changed the transmission fluid recently but after a few days it wanted to stay in the lower gear longer than it did before. After a week of this I changed the fluid again thinking I had not followed the instuctions correctly. Same results. It shifted perfectly for about 4 days then started hanging longer in each gear before changing.
Anyone have any suggestions for my issue?
Thanks
Thanks
#39
Thanks
Thanks
#41
Re: (sony224422)
Non-issue, can always refill through the dipstick if that happens.
"as it did to me"
Since then ive just funneled fluid through the dipstick pipe. no issues.
#42
H-T Order of Merit
#43
#45
And i hope you are using Oem Honda Fluid on the 99-02 accord auto tranny, I had a 99 that i got with a bad trans. and they said they put in a used transmission when i got it and filled it with orilleys fluid it wouldnt go down the block with out slipping hardcore so i put dw-1 Honda fluid in 6 drain and refills 3 qts at a time and got 20,000 miles out of the broken trans. lol could have gone more but it got totaled And when you stop at a light it would bang down into gear lol But that Honda dw-1 fluid kept it strong and it seems like it needs a better trans. cooler because when the a/c fans were on it ran a whole lot better
#46
H-T Order of Merit
#47
um hey im new and I know this is probably already answered but I need a quick answer before my poor litl car blows! Ive got a 99 accord coupe 5spd /160,000mi .e replaced everything axels, spark plugs, wires, dis.cap, now ive got cylinder 4 misfire (mechanic said probably bad exhaust valve) car is seriously lagging...cuts off randomly its a str8 so I can just jump start as im rolling lol also trans fluid..how do I put more...my dads a mechanic just don't have a lift...I need cheapest route!
