cel while driving.
Old Jul 29, 2006 | 09:18 AM
thatasiankidtony's Avatar
Default So i'm driving..
Yesterday as I left work my car felt a little sluggish and would accelerate as normally, a few minutes later the CEL light came on so I pulled over and popped the hood and....the Spark Plug wire popped out somehow. plugged it back it and the CEL lights still on not blinking or anything just on, Car has no mods what so ever. It's a 97 SE. Anyway I can clear it?
Old Jul 29, 2006 | 09:29 AM
Intense3.2's Avatar
Default Re: So i'm driving.. (thatasiankidtony)
Unplug the battery for 60 sec. & see if that works for you. Im not sure if that would have caused a CEL tho..
Modified by Intense2.2 at 2:56 PM 7/29/2006
Old Jul 29, 2006 | 05:34 PM
teamlegacy's Avatar
Default Re: So i'm driving.. (Intense2.2)
It would cause a misfire cyl #x code.
Old Jul 29, 2006 | 07:06 PM
BLKFLSH's Avatar
If you disconnect the battery, I hope you have the radio code (stock radio). There should be a fuse you can pull, to clear codes, without having to enter the radio code, but I'm not sure which fuse it is for your model Accord. Check the FAQ, at the top of the Accord page. I'm sure it will tell you which fuse to pull. Good luck, and Happy Hondaing
Old Jul 30, 2006 | 04:05 AM
Duane_in_Japan's Avatar
Default Re: So i'm driving.. (BLKFLSH)
Dont clear the check engine light until you get the code, it may be a generic code so go to autozone and get it checked out, also if you do a couple to a few more drive cycles with no repeat then the light will go off by itself, check it out yo. A misfire code will be P0300 seies due to the plug wire popping off, where does this wire go, into the head cover (valve cover) did it pop up and away from the spark plug, what style is it.
Old Jul 30, 2006 | 02:28 PM
Thanks for all the replys. Took it to my mechanic, since the battery thing didn't work. He cleared the code for me for 20.00. Was gonna charge me 65.00 but talked him down. Anyway the car runs normally now. And the CEL hasn't come up again.
Old Jul 30, 2006 | 03:40 PM
bdavis's Avatar
Default Re: (thatasiankidtony)
thats a shitty mechanic. $20 to plug something into your car to make something go away that will come back shortly. hope you have another $20!
Old Jul 31, 2006 | 12:50 PM
ricebike's Avatar
Default Re: u coulda done it for free!
don't you have a local autozone? they'll read & clear the OBDII codes fo' free!
keep that in mind next time your check engine lights up again!
Old Jul 31, 2006 | 01:00 PM
dansaleen_04's Avatar
dude mine has popped a couple of times and so has my boys and all we do is jump the cable to read the code and disconnect the jumper and when we turn the car on everytime it goes away. and you dont need a code for the 97 radio stock when unplugging the battery we've messed around with many of them and never required a code for them.
Old Jul 31, 2006 | 07:15 PM
Thanks for the help, the light hasn't come back on yet, driven about 100 miles. and I never knew autozone did that kind of stuff! that's awesome!
Old Aug 1, 2006 | 08:38 AM
ricebike's Avatar
knowing is 1/2 the battle... go JOE!
Old Aug 1, 2006 | 12:17 PM
intezn's Avatar
next time, get it check out for free from the honda dealership
Old Aug 1, 2006 | 12:52 PM
specbb6's Avatar
Default Re: (intezn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intezn &raquo;</TD></TR><TR><TD CLASS="quote">next time, get it check out for free from the honda dealership</TD></TR></TABLE>
what? honda stealerships DO charge you for reading codes, you will need to fix your car in order for it to be free. which is ghey.
sh0rt1e67
16
Apr 30, 2009 09:39 PM
22's and Man Boobs
Jan 17, 2009 11:21 AM
pnthr30
Sep 27, 2004 10:21 AM
kn1ghtrydr
11
Mar 20, 2004 06:32 PM
GeorgeY
Jun 29, 2003 08:59 AM
