CEL problem
Old Feb 26, 2003 | 04:29 PM
RKV's Avatar
RKV
Default CEL problem
ok, like many people kno, i've had a CEL on for awhile, and i checked the code recently, it was 67... i checked the catalytic converter, I removed it, looked fine, it was white inside of it and pretty clear, could see thru it still, no clunk or debris in it when i took it off... is this just cuz of the dime size crack i have on the header? header part that is near the heat shield, is where the small crack is, pretty scrathed up, but i kno u can repair it i heard. friend jumped a curve a year ago pretty badly, couldnt drive, cuz i was drunk, she is just a bad driver. got a new header im about to install. i have bad gas mileage cuz the o2 sensor must be reading the extra air that must be going thru the exhaust manifold, thus, running rich. o2 sensor was replaced recently on the header, and the cat. and why is the ABS light blinking when i performed the CEL procedure, i believe 9 flashes, 8 long, 1 real fast one at the end, this is for the ABS light, NOT the CEL...
question is, can 67 be explained by the crack on the header? and why is the ABS light blinking when doing this service connector check. one more thing, i passed emission guys last week, with this CEL problem. i have a 98 accord I4.
[Modified by RKV, 8:29 PM 2/26/2003]
Old Feb 27, 2003 | 04:22 PM
RKV's Avatar
RKV
Default Re: CEL problem (RKV)
any1?
Old Feb 27, 2003 | 05:25 PM
Chiovnidca's Avatar
Maybe, fix it first.
The ABS control unit has a code stored. Code 81 indicates a bad ABS control unit. Try clearing the code and see if it comes back.
Old Feb 28, 2003 | 08:19 AM
RKV's Avatar
RKV
Default Re: CEL problem (Chiovnidca)
thxs bro, will do... but in more detail, when u mean a bad unit, u mean, the actual ABS system or the unit which controls the light? cuz if its the actual system, that is not a good thing LOL
FAb5
Honda Civic (2006 - 2015)
28
Dec 30, 2009 08:22 PM
johnclaunch
28
Nov 27, 2006 10:12 PM
- BSeRiouS -
Honda S2000
Sep 6, 2006 10:09 PM
drjondurst
Jun 16, 2003 09:46 PM
TypeR 599
Aug 27, 2002 09:01 AM
