camshafts
camshafts
hey guys i am building my girlfriends 94 4dr up and i was wondering what is a good camshaft to put into it i have allready p&p it headers intake h23 itm & tb high flow cat crank pulley and power pulleys
Re: camshafts (allmtrdc4)
Actually i've heard about nothing but total crap about Gude.
HOWEVER, what i DO know, is there's this young man called Bisi. He makes 10.37 runs with an F22 and he swears by RSmachines.com Hit them up and see what they can do
http://www.rsmachines.com
1 Post
Re: camshafts (accordselux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordselux »</TD></TR><TR><TD CLASS="quote">Actually i've heard about nothing but total crap about Gude.
http://www.rsmachines.com</TD></TR></TABLE>
might we throw in that its in a crx w/ tubular frame, carbed f22b2......
Re: camshafts (fw190bvi)
But hey, it's an F series boy! Show some pride even if it's not in an accord. Now all the little ricers want to carb their accords----i'd love to see THAT happen
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi »</TD></TR><TR><TD CLASS="quote">
might we throw in that its in a crx w/ tubular frame, carbed f22b2...... </TD></TR></TABLE>
Actually, my crx is a full unibody, without an inch cut from it, with a stock hatch and stock windshield. My best time at an event is 10.02@135mph. We have done much better in testing.
You should be proud to own accords. Our F22 makes almost 400 hp all motor.
The only accord cams I have available is for full race applications: http://www.bisimoto.com
For mild street, http://www.webcamshafts.com is your best bet. Talk to Debbie.
Re: camshafts (Bisimoto)
That's great. I was thinking about putting my old F (which has a Gude cam) into a Civic, but still think if I had the money a B or K or H is still a better platform to work with. Why did you stick with the F? Price? To be different and original? It was the only block sitting around? The F looks to be a good light strong motor.
My F22 ran great and strong with a Gude cam... until the AEM cam gear slipped. I didn't do my own work at the time and the mechanic said no harm was done but the motor never felt good again after that. I've yet to open it up or even do a compression or leakdown test on it but I'm sure at least one intake valve isn't sealing. So I really can't say if I was happy with the Gude cam or not, I do remember the motor feeling abnormally strong, but it was only on for 100 miles or so before the cam gear slipped.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bisimoto »</TD></TR><TR><TD CLASS="quote">
you sir are awesome. sniff...makes me so proud.....just wondering, how much torque does it put out?
Re: camshafts (4doorH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4doorH22 »</TD></TR><TR><TD CLASS="quote">That's great. I was thinking about putting my old F (which has a Gude cam) into a Civic, but still think if I had the money a B or K or H is still a better platform to work with. Why did you stick with the F? Price? To be different and original? It was the only block sitting around? The F looks to be a good light strong motor.
I like the F series (non-vtec) for the following reasons:
1. Port angles (higher and superior to the b, h and d)
2. Valve angles (I can get away with designing radical lift cams without the valvehead collision factor of dohcs)
3. Less rotational mass and less friction loss (one cam, instead of 2)
4. Uncharted waters (I love experimenting)
5. Cost (these motors are cost effective)
The head holds the most potential for power. I am impressed with the flow numbers we were able to obtain from a modified stock F22 head. The biggest advantage that dohcs have is the ability to tune lobe separation. SOHCs have to have theose grinded in to change. Once you have the perfect lobe angles, it doesnt matter.
4door, you should perform a leakdown on you motor. It seems that you bent a few valves.
Secksi, my F makes 289 ft/ibs of torque, on gasoline, to the crank.
Ah, that's right. For a race motor that is going to spend its time in the high range of the RPM scale, VTEC is rather pointless (even a hindrance due to the extra weight and complexity). And of course VTEC is only really good for boosting low end torque (or top end power depending how one looks at it).
The reason I chose the H over the F was for the DOHC. You have pointed out to me one "pro" of SOHC platform I was not aware of: port and valve angles. For the newbies out there that are unaware of the pros and cons of each:
SOHC:
pros:
1) the aforementioned port and valve angles.
2) your aforementioned less rotational mass and less friction loss (although I would add that as the single cam has more lobes, SOHC makes for a heavier camshaft than a (non-VTEC) single DOHC camshaft, but total rotational valvetrain mass is lower for SOHC)
3) less parts (technically more reliable).
cons:
1) unable to adjust intake and exhaust valves independently (but as you've said once you've found your perfect timing, duration and lift it doesn't mater).
2) heavier camshaft due to number of lobes.
3) non-central spark plug location.
4) asymetric intake/exhaust port/valves
DOHC:
pros:
1) centrally located spark plugs.
2) lower individual camshaft mass due to less lobes vs SOHC.
3) independent adjustment of intake and exhaust valves.
4) intake/exhaust valve/port symetry.
cons:
1) more complex.
2) valve angles?
3) higher total valvetrain mass vs. SOHC
Did I miss anything?
SOHC:
pros:
cons:
DOHC:
pros:
cons:
1) more complex.
2) valve angles?
I beg to differ on 3 of your DOHC pros:
Port symmetry, camshaft mass and sparkplug placement,
So many dohc heads have port profiles that differ from each other. I do not see such casting differences in F heads.
The mass cummulation of 2 cams with lobes that actuate intake and exhaust separately does not negate one camshaft with 16 lobes. The individual cam and sprocket weights are signficant, and the friction loss due to multiple cam journals are nothing to sneeze at.
In regard to spark plug placement, without giving away too much, the position of the sparkplug in the F head allows an ideal "pocket" for a more efficient combustion...when also incorporated with the ideal piston dome design (I love Arias pistons) tons of power can be realized. You will not believe the power loss with a centralized plug on a max dome piston, and how much the charge burn can be hindered upon combustion.
I have said too much!
My looks-go-on-paper logic is that after the intake and compression stroke, the air/fuel mix is (ideally) evenly distributed within the entire combustion volume, and the best place to start the combustion process would be right in the center (relative to bore) of that air/fuel mix. But hey with who-knows-what-kind-of-swirl is going on in a combustion chamber and flame propagation dynamics (like engine knock being the air/fuel mix igniting even before the spark plug fires) being so complex what looks good on paper doesn't always translate to the real world huh.
I would also assume intake and exhaust cycles ideally being equally efficient, hence identical, symetrical intake and exhaust port/angles being a good thing. As you've shown there are always exceptions to the rule.
1 Post
my bad.....but regardless, you are god
haha....i bet when you first started out(and werent so famous ) that if you smoked someone on the track, afterwards when they found out not only did they get beat by a crx, but an all motor non-vtec f series.....**** all of you who doubt the f!!!!
