A/C problem
Old Sep 7, 2005 | 07:44 AM
bon3's Avatar
Default A/C problem
Hey guys,
My I've just recently installed a new radiator on my 91 honda accord lx, and everything seems fine now... except that when i turn on the A/C, its not blowing cold air like its suppose to. The A/C did work recent to the radiator swap. I made sure all connecting sensors were plugged in.
Any suggestions???
Old Sep 7, 2005 | 09:45 AM
amckee's Avatar
Default Re: A/C problem (bon3)
Are your cooling fans running when the air is on? Is the compressor running? You may have trapped air in the coolant passages from your radiator swap. Should have a bleed screw on top hose housing.
Old Sep 7, 2005 | 08:45 PM
deserthonda's Avatar
chk the wiring at the rt side low part of radiator, red wire goes to compressor make surw it is connected
Old Sep 9, 2005 | 06:11 AM
bon3's Avatar
Default Re: A/C problem (deserthonda)
Hmmm... some good suggestions, will try....
Gianna Garofalo
Aug 7, 2018 05:29 AM
davidfillups
Dec 7, 2010 02:20 PM
luzana
Sep 19, 2010 07:37 PM
nickhans
Oct 28, 2005 07:46 AM
TenaciousC
Aug 22, 2002 02:11 PM
