Brake problems
Old Nov 20, 2002 | 12:27 AM
MyYellowHonda's Avatar
New User
Default Brake problems
Hey guys,
This is for my mother.. she owns a 95 Accord and shes experiencing some brake problems.
We're not sure exactly when it happens, but just randomly. The brake pedal requires more and more push before the car slows down. It's as though the braking point goes deeper and deeper.
Like you would normally push the pedal about an inch for it to slow down, sometimes (like i think when the car is going downhill) the brakes fade and you have to push the pedal wayyyy further down to apply the same braking effect. This is also linear, it dosn't just kick in, but the transition is smooth, but only occurs occasionally, i noticed it when i was slowing down as the car was riding downhill. Mum thinks it also happens sometimes when you're coasting very very slowly.
Please help us out if you can.
Thanks!
Old Nov 20, 2002 | 03:11 AM
Chiovnidca's Avatar
Default Re: Brake problems (MyYellowHonda)
Master cylinder maybe?
Old Nov 20, 2002 | 03:41 AM
urbanlegend21's Avatar
New User
Default Re: Brake problems (Chiovnidca)
check your fluid, if it is not low flush the system you might have air in the lines or water might have collected in the lines
if it is not that move onto your master cylinder
Old Nov 20, 2002 | 04:44 AM
Stew Pidasso's Avatar
Default Re: Brake problems (urbanlegend21)
If it's the original brake fluid definitely do a flush. Over time brake fluid absorbs water and that lowers it's boiling point. When the brake fluid boils, the pedal gets spongy and soft like there is air in the lines. Flush first then check the master cylinder as said previously.
Old Nov 21, 2002 | 05:27 PM
New User
Default Re: Brake problems (Stew Pidasso)
Thanks for the answers guys
Old Nov 21, 2002 | 09:32 PM
RotaryBzzz's Avatar
that's what i was thinking...maybe a big air bubble partially gets trapped in the cylinder body every now and again...therefore the inconsistent brake pressure.
kinda like:
brakes "acting up"
[-------](ooo)
brakes "ok"
[-------------](ooo) <---thats the air bubble, outer lines = master cylinder body...
when the air bubble is in the master cylinder...the piston will "blow-by"...
[Modified by RotaryBzzz, 10:34 PM 11/21/2002]
Old Nov 21, 2002 | 11:41 PM
fe519's Avatar
Default Re: Brake problems (RotaryBzzz)
i think the best thing to do is first check the pads... then bleed the brakes... then move to the master cylinder
Old Nov 22, 2002 | 04:24 AM
New User
Default Re: Brake problems (onetym408)
no no no, nothing got to do with the damn brake fluid, it is your brake pads, they are worn out gosh, replace them
learn english then study up on brakes, there would be a totally deifferent braking problem if they were worn out
jwlee7ucla
Apr 14, 2024 07:41 AM
curtie94
Apr 9, 2011 05:01 PM
stripes777
Oct 28, 2006 11:16 PM
mikehawkBUiLT
24
Sep 16, 2004 12:06 PM
GSR95T
Sep 4, 2002 09:21 AM
