Bottom cover loose.
Old 01-02-2015, 11:32 AM
Canucksfan101's Avatar
Default Bottom cover loose.
Hi,
I have a Honda accord 2002 SE
I'm not sure what it's called but there's a black cover that is loose and it's located at the bottom of the car under the engime. When I was changing my transmission fluid I saw it was loose and needed some clips. Could someone tell me what is the cover called and would zip ties work in securing the cover?
Thanks in advance!
Old 01-02-2015, 11:48 AM
Radial Accord's Avatar
Default Re: Bottom cover loose.
splash Shield. When You Use ZipTies They Get brittle And Break So No, If You Can Buy The Clips At Your Parts Store Ask For TheM They Are Inexpensive
Old 01-02-2015, 02:59 PM
I called my local parts store NAPA they told me to bring a sample clips but there are no clips on the guard. As it held by two screws at one each side
Would you know the name and size of the clips?
Thanks!
Old 01-02-2015, 03:09 PM
MM Gruppe B
MAD_MIKE's Avatar
90657-SB0-003 011 002 CLIP, SPLASH SHIELD 3.63
91503-SZ5-003 013 005 CLIP, BUMPER __FACE 3.57
91512-SX0-003 014 020 CLIP, FENDER (INNER) 1.55
You probably do not need 20 of the SXO clips, as they are used on the inner fender as well as the shield.
Verify what you need before ordering.
codenamezero
02-10-2007 09:00 AM
Prudz_lude
12-16-2006 09:12 AM
SpiceyRice
02-12-2005 07:13 PM
dLo GSR-stolen-now-WRX
11-06-2002 12:41 PM
PiYoImuT
11-04-2001 12:10 PM
Quick Reply: Bottom cover loose.
