Bleeding abs
Old Sep 10, 2011 | 09:50 PM
75aces's Avatar
Default Bleeding abs
Is there a write up to bleed the abs on a 96 accord sedan?
Old Sep 11, 2011 | 04:26 AM
sl0waccord's Avatar
Default Re: Bleeding abs
Here are the directions I followed.
Fluid should not go down then back up. Itsounds like theres air in there. Try bleeding the ABS. Based on my former Integra, it should be about like this...
Bleed screw is probably near ABS fluid reservoir. Find a hose & a jar. Hose should fit good; if it pops off the pressure is high enough to be dangerous.
Run engine to pump up ABS. Shut off.
Crack open ABS bleed screw just barely, because the pressure is high.
As soon as it stops flowing, shut it again.
Run engine to pump ABS back up. Shut off engine. Refill reservoir.
Repeat until you dont get any more air bubbles from the bleed screw.
http://www.hondaaccordforum.com/foru...-accord-21933/
eagle458
Feb 3, 2014 10:24 PM
fastfrog
Jul 18, 2010 09:33 PM
AtoZ
Nov 28, 2009 09:59 AM
bonh
Jun 28, 2007 12:15 PM
jonzel
Aug 18, 2005 04:47 PM
