Big problem need help
Old Apr 17, 2007 | 08:43 AM
poncho2049's Avatar
Default Big problem need help
i work at a shop called import autosport and i am new to this forum but we got a 95 accord in recently and we cant figure out what the deal is
It turns on and idles for about 30 seconds then the tach starts bouncing in between 1500 and 750 then it just dies, Have replaced ignitor and coil all the fuses and i suspect the injector drivers are beginning to crap out, i will be using a stethiscope to listen to injector pulse untill it dies but if you know anything or have any ideas it would be much appreciated and if it is the injector drivers please direct me to a new or used ECU at a good.
Thanks
Modified by poncho2049 at 9:58 AM 4/17/2007
Old Apr 17, 2007 | 08:47 AM
jweller's Avatar
Default Re: Big problem need help (poncho2049)
have you checked what the IAC valve is doing
Old Apr 17, 2007 | 08:53 AM
GhostAccord's Avatar
Default Re: Big problem need help (jweller)
This bouncing idle can stem from many different problems. Is there any CEL?
First you could try checking for Vacuum Leaks, usually clean out the air bypass systems in the Throttle body and intake will cure this. IACV, FITV, AICS check them all for operation and clean them.
There are a bunch of treads on here now running with these same symptoms
Check in the Accord FAQ
Engine
Cleaning the Idle Air Control Valve (IACV), Fast Idle Thermo Valve (FITV) and Throttle Body (TB)
https://honda-tech.com/zerothread/1844067
Modified by GhostAccord at 2:44 PM 4/17/2007
Old Apr 17, 2007 | 09:00 AM
poncho2049's Avatar
Default Re: Big problem need help (GhostAccord)
why not go to import autosport
Old Apr 17, 2007 | 09:02 AM
poncho2049's Avatar
least i dont own a honda
Old Apr 17, 2007 | 09:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poncho2049 &raquo;</TD></TR><TR><TD CLASS="quote">why not go to import autosport</TD></TR></TABLE>
OK sorry didn't mean to flame on ya but after you said that you worked at a shop and on here looking for help I thought it was kind of funny.
Modified by GhostAccord at 2:45 PM 4/17/2007
Old Apr 17, 2007 | 09:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poncho2049 &raquo;</TD></TR><TR><TD CLASS="quote">least i dont own a honda</TD></TR></TABLE>
What do you work on then??
Modified by GhostAccord at 2:47 PM 4/17/2007
Old Apr 17, 2007 | 09:36 AM
poncho2049's Avatar
we specialize in mercedes, Saab, porcshe, VW, and MG's, we dont see hondas a whole lot and not every shop will know everything about every car, sorry for bothering you
im just man enough to ask for help
Old Apr 17, 2007 | 09:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poncho2049 &raquo;</TD></TR><TR><TD CLASS="quote">we specialize in mercedes, Saab, porcshe, VW, and MG's, we dont see hondas a whole lot and not every shop will know everything about every car, sorry for bothering you
im just man enough to ask for help </TD></TR></TABLE>
Hey man sorry for flam'n. I totally understand where your coming from and i apologize.
Old Apr 17, 2007 | 11:09 AM
poncho2049's Avatar
i was just kiddin man its cool thanks for the help i do appreciate it greatly
Old Apr 17, 2007 | 12:19 PM
Old Apr 17, 2007 | 12:36 PM
JimBlake's Avatar
I was just going to point him to the big thread on cleaning FITV, IACV, etc...
then I noticed you had already linked it. It's a pretty good summary of anything that can cause a surging idle.
That stuff is good - IF the idle rpm is really surging. If it's just a flaky tach & the actual rpm is steady, then let us know & we'll think along those lines.
Knowing Saabs & VW, I'd guess you're not accustomed to cars that have throttle position sensors. Check that out on the Honda, it can contribute to the problem. Somewhere around here (search) there's a thread or 50 about what voltages you want to see from the TPS when it's closed & wide open.
Old Apr 18, 2007 | 06:00 PM
poncho2049's Avatar
Default Re: Big problem need help (JimBlake)
it ended up being the distributor one's coming on wed.
Thanks guys
jdm95
Sep 26, 2009 03:47 PM
diydog
Jan 21, 2009 09:33 AM
asianrepnsb
12
Mar 8, 2008 12:26 PM
ucmugenaccord
Feb 27, 2006 08:15 AM
drisken
Sep 9, 2004 09:41 PM
