Best oil filter to use?
Old 07-23-2001, 03:19 PM
New User
tran1981's Avatar
Default Best oil filter to use?
It is time to change oil filter. Which is the best oil filter? Do u get any performance gain w/ better oil filters?
Old 07-23-2001, 04:43 PM
SOHCArchangel's Avatar
Default Re: Best oil filter to use? (tran1981)
stp, bosch or mobil 1, i would stay away from the others, they are junk, or the best to use in my opinion is a jdm honda filter,...if you can find them...
Old 07-23-2001, 06:07 PM
Conechaser's Avatar
Default Re: Best oil filter to use? (SOHCkordVTEC)
Get one from the Honda Dealer, $5
Old 07-23-2001, 10:30 PM
New User
tran1981's Avatar
Default Re: Best oil filter to use? (94Accord)
What about the k&n gold oil filter? Are they any good?
Old 07-25-2001, 09:08 AM
Dent Free's Avatar
HONDA its what they put on the cars so you know the will be good
PLUS . . . they have a anti-drain flap that keeps oil from draining out when the engine is off so when you start it it will already be at the engine and won't have to go through the filter first.
just my 2 's
Old 07-25-2001, 12:07 PM
Default Re: Best oil filter to use? (Dent Free)
well the only good honda filter is the jdm filters, the usdm and canadian honda filters are the same as fram crap...sorry guys...
Old 07-25-2001, 06:36 PM
New User
tran1981's Avatar
Can u get jdm oil filter in US? I read reviews and usdm oil filters are crap too (like fram).
Old 07-26-2001, 06:09 AM
im still trying to find them, if i do ill post where i found them....
Old 07-26-2001, 09:37 AM
New User
accordsir_h22a's Avatar
Honda filters aren't crap. They are better than FRAM, I know that. I have a Honda HAMP filter on my car now, and it isn't really keeping my oil any cleaner than the one I can buy at the Honda dealer. HAMP is JDM Hondas factory performance parts, kinda like TRD/Toyota, and NISMO/Nissan. Factory USDM Honda filters are made by Filtec, which from what I know has no affiliation with FRAM. I wouldn't waste my money on a K&N or a Mobil filter, just get a factory filter from the Honda dealer for $5, and it will do you just as good.
Old 07-26-2001, 09:47 AM
Default Re: Best oil filter to use? (accordsir_h22a)
dude, my previous post stated: "well the only good honda filter is the jdm filters, the usdm and canadian honda filters are the same as fram crap" the construction of the fram and honda filters are identical here I never said they were from the same manufacturer: http://www.ntpog.org/reviews/filters/filters.shtml
Old 07-26-2001, 10:15 AM
New User
OK Dude (LOL). If your gonna make up your mind about what filter you want to use, but the results of this little test this guy did, then that's fine. I ain't mad at ya. I read through it, and most all of his information is in theory, not real/true testing. You can't really judge a filter by just taking it apart. Ever look at a factory Honda air filter? They have little tiny fibers all over the place, but the car still lasts a very long time using a factory filter. The reason that Japan has a special filter is because most all of there cars come equipped with some kind of a twin cam VTEC engine, that would need special filtering like that. I think these expensive oil filters are over rated just like the fancy spark plugs, and plug wires. You just don't need those things on a factory USDM engine in order to make them go faster or last longer. Just my 2 cents.
Old 07-26-2001, 10:41 AM
oh well
Old 07-27-2001, 10:39 AM
New User
NineTwoAccord's Avatar
honda filters have whats called a "checkvalve". like someone stated before this keeps oil in the engine when it is not running. when it starts up there is still oil in the system. get the honda filter, there is NO reason to get an expensive aftermarket oil filter. just change your oil every 5000 miles and run the car to over 200k miles.
our generation is WAY to wrapped up in marketing. they hire people just to think of schemes to compel people to buy a product.
"if you dont have a good product, you need a good marketing department"
Old 07-27-2001, 11:15 AM
Default Re: Best oil filter to use? (NineTwoAccord)
every oil filter available out there has an anti-drainbvack valve, and 5000 miles is waay too much, i usually do 2000 mile intervals, less if racing
Old 07-27-2001, 11:59 AM
Banned
CardDealer's Avatar
Modified by CardDealer at 4:16 AM 11/16/2006
Old 07-30-2001, 02:51 PM
New User
uhm, no. not every filter has a checkvalve. and 5000 miles is less then the 7000 miles recommended by honda (check your manual). if you want to change it every 2000 go for it but it is not needed except maybe to sleep better at night.
98GSRDC2
03-26-2007 02:42 PM
E.G.sAvAgE
02-08-2007 11:03 PM
Halo
26
07-04-2006 04:43 AM
Cyrio
10-07-2002 05:12 PM
TurbothisLS
02-10-2002 09:07 AM
Quick Reply: Best oil filter to use?
