BAD CRANK SENSOR THROW CODE?
Old Mar 31, 2016 | 05:10 PM
1yesfan's Avatar
Default BAD CRANK SENSOR THROW CODE?
Would it on a 2001 Accord LX 4 cyl Vtech
I ran for codes I have nothing.
Old Mar 31, 2016 | 06:45 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: BAD CRANK SENSOR THROW CODE?
The sensor may be bad, if it is not an open circuit it may not throw a code.
Check the senor resistance and verify the wire harness and various connections up to the distributor and harness are not corroded, damaged or loose. Look for damage to the wire harness.
Next step would to be physically exam the sensors. If road debris/junk has attached to the sensor(its a magnet) it will reduce the resolution from the sensor and the PCM will not receive a signal from the sensor.
No crank sensor, no spark and no fuel.
Old Apr 1, 2016 | 04:51 AM
1yesfan's Avatar
ok, I have gas and spark, so my issue is not the crank sensor. I am having hard starts and an attempted stall on the way home last night.
Fuel pump? Ignitor? Relay?
Old Apr 1, 2016 | 12:31 PM
MAD_MIKE's Avatar
MM Gruppe B
Did you test and inspect the sensor?
It's an intermittent issue, need to eliminate components as good/bad.
Old Apr 1, 2016 | 12:59 PM
1yesfan's Avatar
No I have not tested it. Appears it is a little work to get to it.
Old Apr 6, 2016 | 08:01 AM
1yesfan's Avatar
on a 2001 will it throw a code if it is sporadic in working properly???????
Pulled main relay per many folks on the net and other forums say can be the issue. Mine looks brand new. had an electrician at my job look at it, he says it look new. No bad solder or a crack in anything.
If this is a crank sensor that comes and goes should I not see CHECK LIGHT???
I think I will try a used dizzy next. My components in mine are HITACHI. I assume I need the same type of dizzy then.
Old Apr 6, 2016 | 12:52 PM
1yesfan's Avatar
well how do I test the sensors when they are behind the timing cover????? is there a diff place?
Old Apr 6, 2016 | 03:56 PM
holmesnmanny's Avatar
Is your spark blue ? How old are your spark plugs, cap, and rotor ?
civic1999si
Nov 2, 2019 06:25 PM
unusual71
K Series
Apr 18, 2017 02:24 PM
JohnnyVolcom5
Honda Civic (2001 - 2005)
Aug 3, 2014 06:45 PM
saywhat
Dec 5, 2004 09:41 PM
90h22acrx
Oct 8, 2004 07:58 PM
