axle lifespan...
Old 04-19-2011, 01:09 PM
jamzx3's Avatar
Default axle lifespan...
just got my car back from getting an alignment. left front says i have -1.9* of camber, 2.6* of caster and .04* of toe....front right reads -2.4* of camber 3.5* of caster and .01* of toe....left rear has -2.6* of camber and .10* of toe...right rear has -2.2* of camber and .12* of toe...front what i've searched i should not worry about the little extra neg. camber that i have...
when i was paying they told me that since the car is really lowered...bout 2.25 up front and 2.5 in the rear that the drop is putting extra stress on the axles because they are short and the angle at which they are coming out of the transmission...i asked them if it mattered that i have prelude axles in that are a little longer and he said no...said that there was grease on the underside...axles have only seen about 75 miles on the road...please tell me what you think
Old 04-20-2011, 12:37 PM
jamzx3's Avatar
Default Re: axle lifespan...
bump...
Old 04-21-2011, 03:15 AM
MM Gruppe B
MAD_MIKE's Avatar
You should be able to inspect the outer CV boots by removing the wheel, placing the transmission in Neutral and spinning the axle. Look for tears or wet spots on the boots. The inner boots will be harder to inspect, but if you can beg/borrow/steal some ramps to drive the car up onto and inspect the inner boots the same way.
If they did not tell you a specific boot or side, they may be talking out of their ***.
Old 04-23-2011, 07:51 PM
jamzx3's Avatar
i checked under the car...grease all over the passenger side...what would cause the boot to tear/rip in under 100 miles of driving?
Old 04-24-2011, 12:47 AM
MM Gruppe B
MAD_MIKE's Avatar
The boot is made of crap quality it may tear itself apart under centrifugal force.
The installer was not careful and damaged the boot.
The boot was installed incorrectly/wrong boot for the axle.
The axle is the incorrect length and is placing too much tension on the boot.
Too much grease used on assembly of the axle.
Old 04-24-2011, 06:44 AM
jamzx3's Avatar
thanx for getting back to me mike...the axle is an oreilly's autoparts axle, i stalled both driver and passenger side axles, they are prelude axles which on the passengerside, which is the one blowing the grease is about 1/4 longer than the stock accord axle...using it because i'm using roh and when i put the car back together i didnt like that the axle nut didnt sit flush with the end of the axle...the person that i bought it from saifd to use the prelude axles which ended up sitting perfect for the axle nuts....
on a side note...i see your location as c.v., ca...is that the coachella valley?....if it is i came to nebraska from d.h.s.
Old 04-24-2011, 11:15 AM
MM Gruppe B
MAD_MIKE's Avatar
That is probably compressing the inner boot just enough to allow it to ballon at speeds and pull itself apart.
I take it the car does not have CL type hub over conversion?
No, I'm up North near Hayward.
What you will probably need to do, is use the outer stub axle and CV joint mounted onto an Accord axle. That way you will have the correct length stub axle, and correct length main shaft.
bopbop93030
04-06-2008 08:32 AM
projectTeG
Suspension & Brakes
04-30-2005 05:56 PM
Wazup
Suspension & Brakes
04-29-2005 08:10 PM
alfaaay
03-21-2003 06:30 PM
rioninja
08-22-2001 02:21 PM
Quick Reply: axle lifespan...
