Auto Transmission Fluid
Old 12-12-2005, 01:02 PM
garrybloom's Avatar
Default Auto Transmission Fluid
I have a 90 Accord LX and went to check the transmission fluid level and could not find where to do this. Can anyone help?
Thanks
Old 12-12-2005, 01:04 PM
iam7head's Avatar
Default Re: Auto Transmission Fluid (garrybloom)
are you kidding me? there's a dipstick which is sticking out of, well, the tranny.
you see the loop with yellow rubber around it? there's on for motor oil and the shorter/lower one is for atf
Old 12-12-2005, 01:09 PM
YeuEmMaiMai's Avatar
on your car you need to
stand in front of car
on left side of car the dipstick is down low and on my car (a 94 LX) the handle is reddish brown. it is a small dipstick on the front of trans near the bottom of transaxle.
bizzy11's Avatar
Default Re: Auto Transmission Fluid (iam7head)
I was told that every time you replace the tranny fluid the drain plug should be replaced. Is that true?
Old 12-12-2005, 01:32 PM
iam7head's Avatar
Default Re: Auto Transmission Fluid (bizzy11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bizzy11 &raquo;</TD></TR><TR><TD CLASS="quote">I was told that every time you replace the tranny fluid the drain plug should be replaced. Is that true? </TD></TR></TABLE>
the washer should be replace, the plug is replaceable only if it's stripping
Old 12-12-2005, 01:40 PM
bizzy11's Avatar
Is the plug easy to find? I have done everything to all my cars except replace the tranny fluid. I does not sound hard to do.
Old 12-12-2005, 01:44 PM
yeah it is in the rear of the transaxle
Old 12-12-2005, 01:48 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bizzy11 &raquo;</TD></TR><TR><TD CLASS="quote">Is the plug easy to find? I have done everything to all my cars except replace the tranny fluid. I does not sound hard to do.</TD></TR></TABLE>
IT is not hard to do, you can see a plug that have a 3/8 slot, stick your 3/8 racket and turn it loose.
make sure you flush and refill it three time.
Old 12-12-2005, 01:56 PM
bizzy11's Avatar
How do i flush and refill?
Old 12-12-2005, 01:57 PM
when you take the plug out, the fluid will drain. refill with approximately 3.75 quarts.
Old 12-12-2005, 02:07 PM
iam7head's Avatar
you done everything to you car and you can't do a flush and refill?
if you can't figure out that part then..don't bother doing it yourself
Old 12-12-2005, 02:08 PM
iam7head's Avatar
Default Re: Auto Transmission Fluid (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">when you take the plug out, the fluid will drain. refill with approximately 3.75 quarts.</TD></TR></TABLE>
the torque converter will not let you drain out all the ATF, that's why you have to drain and refill at least three time to get all the dirty juice out
Old 12-12-2005, 02:14 PM
bizzy11's Avatar
I can figure out what flush and refill is, but i mean that i have never done it. I will change the tranny fluid myself, never had a problem doing anything to my car.
Old 12-12-2005, 02:18 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bizzy11 &raquo;</TD></TR><TR><TD CLASS="quote">I can figure out what flush and refill is, but i mean that i have never done it. I will change the tranny fluid myself, never had a problem doing anything to my car. </TD></TR></TABLE>
well, i didn't say you cannot, but sir, you asked the question yourself.
all i am saying it, if you have enough experience to do the job, go for it.
the last thing i want to do is to teach someone that have no idea what so ever to do something(esp. something as important and expensive as car) and they mess up there car.
i am not trying to be an ****, if i was, i would tell you something about pouring brake fluid into atf hole
Old 12-12-2005, 02:26 PM
bizzy11's Avatar
No prob. Like i said i have done everything to my hondas except motor swap. Fluid change is not big deal, of course it has to be done right. I have never changed the tranny fluid that is why i said that i never heard of flush and refill. Wasent sure if you needed a special flush kit. No problem, i do appreciate your advice however.
Old 12-12-2005, 04:16 PM
iam7head's Avatar
just need a long funnel to refill the atf hole(which is the same hole you pull the dipstick from)
alexdc03
03-26-2012 04:40 PM
tchen415
07-15-2007 09:10 PM
mark_is_gay
04-14-2006 04:49 PM
dork
07-09-2004 02:01 PM
96Prelord
06-05-2002 07:21 PM
Quick Reply: Auto Transmission Fluid
