any help welcomed
any help welcomed
I have a 92 Honda accord ex that has been causing me a bit of trouble. The car will turn over but once its been on for a bit and the temperature reaches a stable level the car will just die out and not want to turn on for a while. Anyone know why it does that or what could be the cause? Any help is useful. Thanks
Re: any help welcomed
Could be a few things,
Fast idle thermal valve out of adjustment
Engine coolant temperature sensor out of range
How long has this been going on for? Is the check engine light on?
First thing you can do is check to see if there are any stored codes on the ECU.
https://honda-tech.com/honda-accord-.../#post33897269
I know it says for 96 but this procedure is the same for all the 90-97 Accords.
giovannie23
07-02-2014 08:18 AM
boosted96midorihatch
05-14-2006 08:40 AM
