Alternator problem or something else?
Old Aug 9, 2004 | 08:39 AM
mbfuentes's Avatar
Default Alternator problem or something else?
1999 EX V6 - replaced original alternator with noisy bearings with a remanufactured from local parts store. Within half a day, charging light, door ajar light and parking brake lights came on. Assumed defective alternator and exchanged it. Within two days same thing happened. This time parts store said alternator checked out "perfect."
Each time lights came on, I put the original noisy one back on so I could use the car. No problems with it.
Anyone experience this problem?
Old Aug 9, 2004 | 10:28 AM
Filthy Focker!'s Avatar
Default Re: Alternator problem or something else? (mbfuentes)
Huh????
Original alternator = no problem...
New alternator = bunch of lights light up in the dash...
DId this problem occur anytime in the past???
fs
Old Aug 9, 2004 | 10:55 AM
mbfuentes's Avatar
Default Re: Alternator problem or something else? (filthy_shovel)
Huh?????????? is right.
No it has never occurred in the past nor did it ever occur with the original alternator.
Installation of the alternator is fairly easy, but with all things easy, I wonder if there was anything I did that would cause this "light show." It wouldn't seem possible so I thought I'd ask.
Old Aug 9, 2004 | 12:41 PM
EX-JAY's Avatar
why not buy a new alternator from the dealer, since you are not having problems with them?
Old Aug 9, 2004 | 04:35 PM
bill-71SS's Avatar
aftermarket alts are junk,buy one from honda
Old Aug 9, 2004 | 06:58 PM
tjohnson329's Avatar
first double check that the alternator your getting from the part store is the correct one. then with the old and the new altenator hooked up check the voltage of both using a voltmeter. since yo put in a new alternator i am surre you know how to check the voltage. the readings should be the same but i am sure the refurb alternator should have a lot lower voltage then the original. it might be better off trying to get a refurb from somewhere else. but i am sure it is altenator prob and not the way your hooking it up. cause you seem to be hooking the orginal back up ok. IMO
Old Aug 9, 2004 | 07:00 PM
rival12's Avatar
Default Re: Alternator problem or something else? (tjohnson329)
check ignition switch (gauge lights) engine turns but dies?
prophecy7115
Mar 8, 2008 05:01 AM
MOVE OVER
Feb 26, 2008 06:15 AM
hondastrtracr
Oct 29, 2007 12:11 PM
Lee_Delso
11
Nov 3, 2004 01:11 PM
raene
Jul 8, 2003 10:17 PM
