Advanced Timing
Old Sep 5, 2001 | 08:49 AM
Tripz's Avatar
New User
Default Advanced Timing
Stock timing for the H and F22's is about 15 degrees with +/- 2 degrees alterations. I know the H series engines have knock sensors but am unsure about the F series engines. keeping in mind, Timing can be advanced to the point where it dosen't trip the sensor...but at what degrees is this?? I know it's hard to say because of different modifications and octane levels, So......forget that question then. I am currently at about 19-20 degrees....but since i bumped it up from 12 degrees....i notice i am burning oil when high revving! Will this much advance cause the engine to burn oil?? what timing are u guys running?? Thanks!
Old Sep 5, 2001 | 09:39 AM
SOHCArchangel's Avatar
Default Re: Advanced Timing (Tripz)
well, that is the nature of the motor, i am pretty up there in ignition advance, almost all the way
Old Sep 5, 2001 | 10:08 AM
4doorH22's Avatar
16 degress, but I can't think of any possible corelation between ignition timing and oil consumtion?!?!
Are you seeing blue smoke or having to top-off your oil a lot or both?
Old Sep 5, 2001 | 10:21 AM
Tripz's Avatar
New User
Default Re: Advanced Timing (4doorH22)
I'm actually seeing black smoke when shifting at high revs...this probablly means i am running too rich tho. I have to top up every now and then after hard driving...but most likley it's the increased temps from the timing advance...I'm going to drop it back a couple degrees and monitor the oil consumption. thanx for the replys
bigblue7t6
Feb 8, 2012 06:32 PM
mortificationrock
Jul 10, 2007 04:26 PM
