My Accord veers to the left when I accelerate :(
Old 03-04-2010, 06:58 AM
Belarus's Avatar
Default My Accord veers to the left when I accelerate :(
Hi guys, I would really appreciate your opinions on my problem. When the car is rolling in the neutral it's rolling straight. As soon as I give it gas it slowly veers to the left lane IF I let go of the steering wheel... Any thoughts? The car is a 2001 Honda Accord Coupe. Thanks!
Old 03-04-2010, 09:53 AM
PilotOnDubs's Avatar
Default Re: My Accord veers to the left when I accelerate :(
check tires, tire pressure, and alignment
Old 03-04-2010, 10:55 AM
Belarus's Avatar
Thanks! But how come it happens only when I am accelerating?
Old 03-04-2010, 11:14 AM
GlassJAw's Avatar
Sounds like your trans is on the way out, is it a V6 by any chance??
I had a similar problem with my old '83 Prelude, turns out it was a kind of torque steer as the differential was binding. I just hope for your sake it is as simple as tyre pressures or wheel alignment as PilotOnDubs has said..... good luck!
Old 03-04-2010, 11:48 AM
Belarus's Avatar
No, it's not a V6, just a regular 4-cylinder engine... So you are saying the differential in your Prelude broke down? How did it happen?
Old 03-04-2010, 12:14 PM
GlassJAw's Avatar
Old age and high mileage really, sometimes if it upchaged whilst heavily accelerating it would try tear the steering wheel out of your hands.
Old 03-04-2010, 02:28 PM
NASOHC's Avatar
Last time that happened to me, the tie rod end was loose - check for wear too!
Old 03-04-2010, 10:42 PM
Belarus's Avatar
All right, I will check that out. Did it occur to you when you were accelerating or at all times?
Old 03-04-2010, 11:38 PM
NASOHC's Avatar
Yeah, mine pulled to the right under low speed acceleration where it was noticeable. As soon as I released gas pedal, it would correct itself. Took me a day to figure it out after lifting the car on a hoist to check under car. I grabbed the wheels and it had play on the right side, noticed the nut came loose, the safety pin had broken off. Lucky I caught it early.
Old 03-05-2010, 12:46 AM
New User
unicorn's Avatar
Hi guys, I would really appreciate your opinions on my problem. When the car is rolling in the neutral it's rolling straight. As soon as I give it gas it slowly veers to the left lane... Any thoughts? The car is a 2001 Honda Accord Coupe. Thanks!
Hello Belarus, as a new member i introduce my self first, my name is David and i am from NY.
In that situation you have to do only one thing go and visit the service center as soon as possible,
Old 03-05-2010, 12:50 AM
Belarus's Avatar
Well, it's definitely not THAT bad in my case. I just feel a very slight pull on the steering wheel - it's just annoying, that's all...
Old 03-05-2010, 12:52 AM
Belarus's Avatar
Thank you David, but before going to a service center I would like to collect sufficient background data on the problem and make an intelligent guess, so that I can tell the mechanic where he has to start, because mechanics around here are in the habit of doing a lot of unnecessary work and ripping their customers off
Old 03-05-2010, 01:21 AM
cstone's Avatar
Props on trying to prevent a mechanic from ripping you off!!!
When the right radius rod broke on my Integra it kinda was like that but mine violently tried to veer right when i accelerated. I highly doubt that yours is broken but the bolt on the end (towards the front) could be loosened up a bit. you might want to check that out.
Old 03-06-2010, 01:30 AM
Belarus's Avatar
Okay guys, here's an update on my troubles: checked tire pressure last night - it turned out pressure in the left tire was even higher than in the right one, which made no sense because the car pulled to the left. I was getting very frustrated and was beginning to think that I had bought a car with a messed up geometry. But today I swapped the front tires and the car started to pull in the opposite direction - to the right!! So I think it would be logical to assume I have a defective tire, right?
Old 03-27-2010, 08:52 AM
Belarus's Avatar
Okay, it was bad rear wheels alignment. Solved.
darcus.t
07-07-2010 04:34 PM
GSRNetics
10
05-01-2008 05:03 PM
clayj
08-05-2007 07:32 PM
JimmyM86
12-23-2006 10:26 PM
Quick Reply: My Accord veers to the left when I accelerate :(
