Valve adjustment for 93 Accord EX?
Old 02-26-2002, 09:50 PM
mickey513's Avatar
Default Valve adjustment for 93 Accord EX?
The car has 71k miles on it. Runs fine but not getting the expected gas mileage. I did the full tune up already, change dis. cap&rotor, spark plug wires, spark plug, fuel filter, and air filter. I get about 240 miles on 11.5 gallon, half city, half highway.
Only thing I havn't done is get the valve adjusted. Do I knew a valve adjustment? The mechnic told me the only time I needed one was when the valve made "ticking" noises, which is not currently doing. But I am not satisfy with how the car is right now. Will I benefit from doing the valve adjustment? Should I get one done and if so, how much will it cost at Honda?
Old 02-27-2002, 05:41 AM
4doorH22's Avatar
Default Re: Valve adjustment for 93 Accord EX? (mickey513)
Dang, only 71K on a '93?
You might want to try a fuel injector/system cleaning additive.
Honda recommends valve adjustment be checked every 30K, maybe even every 15K?
Old 02-27-2002, 06:10 AM
SOHCArchangel's Avatar
Default Re: Valve adjustment for 93 Accord EX? (4doorH22)
doh, ive never had this done
Old 02-27-2002, 07:43 AM
New User
John's Avatar
Default Re: Valve adjustment for 93 Accord EX? (SOHCkordVTEC)
what? you've never adjusted your valves? or you haven't used an injector cleaner?
you can tell when you need to adjust your valves when the F22 motor begins to sound like a diesel motor...
Old 02-27-2002, 07:44 AM
Accord94DX's Avatar
Default Re: Valve adjustment for 93 Accord EX? (DunReit)
ive noticed that the exhaust valves are the only ones ever to need adjustment. I have yet to run into an F22b2 that needed the intakes adjusted.
Old 02-27-2002, 07:48 AM
Default Re: Valve adjustment for 93 Accord EX? (Accord94DX)
man i use injector cleaner, i just never have the valves adjusted, and no it doesnt sound like a deisel, you heard my car man, remember.........
Old 02-27-2002, 08:38 AM
Mark27's Avatar
I've never noticed a difference after using those injector cleaners.
But a test drive of my friend's 92 teg before, and after having the injectors professionally blueprinted gave a nights and days difference. The car doesn't hesitates anymore and gas mileage was a lot better.
might be a bit on the pricey side (I think he paid like $130 for the job), but at least it works
Old 02-27-2002, 03:02 PM
4doorH22's Avatar
Default Re: Valve adjustment for 93 Accord EX? (sting)
Here's the nifty Snap On valve adjustment tool (which I've yet to use on my 11,354-mile motor)
Old 02-27-2002, 03:03 PM
Accord94DX's Avatar
That thing kicks ***!!
Old 02-27-2002, 03:42 PM
New User
Gennady's Avatar
You guys said that when it sounds like a diesel, they should be adjusted. Well, mine does, but a mechanic listened to it and said I dont need it. I have 127k on my car and bought it at 113k. I dont know if they have ever been adjusted. My gas milage sucks *** too. What would you guys recommend?
Old 02-27-2002, 03:46 PM
Accord94DX's Avatar
Default Re: Valve adjustment for 93 Accord EX? (Wont be beat)
if you dont hear it you are good to go. Yaboochi!
Old 02-27-2002, 03:51 PM
New User
Gennady's Avatar
But I do hear it. Its sounds like a ******* Mack truck. Pidaraz!
Old 02-27-2002, 03:52 PM
Accord94DX's Avatar
Well then do the adjustment! Imobeda!!
Old 02-27-2002, 03:59 PM
New User
Gennady's Avatar
Actually, it was the owner of a service shop that sees moded imports daily. All I see is goddamned fart-pipe civics and riced out integras when I go there.
Old 08-28-2015, 06:41 AM
Ronald Morgan's Avatar
hello all I have been working on my 93 10 annv ed over the past 3 months have rebuilt the front new bearings struts rotors pads upper control arms timig belts water pump trans mission flush 2.5 quart twice also seals the car has 205000 on it yet it does not smoke an runs very well for the miles I do believe that an work as far as upkeep does make the car run for more miles than if were not done just because someone said it didn't need it allways do your matince work remember your Honda likes her hair brushed not combed
rijn
09-16-2014 10:19 AM
square_1
05-02-2011 09:37 PM
my93accord
06-09-2010 12:52 PM
Civic89
08-31-2002 08:51 AM
mickey513
03-16-2002 11:50 PM
Quick Reply: Valve adjustment for 93 Accord EX?
