AC Problem
Old Apr 28, 2009 | 05:10 AM
StraightNoChaser's Avatar
Default AC Problem
I've got a 2000 Accord V6 with the auto climate control. When the compressor is hooked into the harness, it won't engage. However, if you run power straight to the compressor it works great. So, what I need to know is, what might cause that? I'm working on it tomorrow and need to get some parts together today. I work at a junkyard, so I'm taking a temp control unit and a high pressure switch home. Are there any other switches or sensors that might keep the compressor from kicking in if they're bad?
Old Apr 28, 2009 | 05:43 AM
billyrusa's Avatar
Default Re: AC Problem
If there is no coolant in the system, the compressor will not engage.
Old Apr 28, 2009 | 05:59 AM
Targa250R's Avatar
be professional
Bingo.
In the vast majority of cases where the compressor will not engage, the system is usually empty of refrigerant due to a leak or puncture. Check the pressures and charge the system as needed; I recommend adding leak detection dye to the system when charging so that you can pinpoint any leaks easily.
The most common leak point is the condenser; they often get punctured by rocks or road debris.
Old Apr 28, 2009 | 06:04 AM
That was my first thought, so I fully charged the system but still couldn't get anything. Thanks for the suggestion though. :> I'll pick up some dye on my lunch break, but I'm pretty sure it's an electrical issue. Just checked the pressure again to be sure and it's right on the mark. Wouldn't that have dropped if there was a leak?
Old Apr 28, 2009 | 07:03 AM
Targa250R's Avatar
be professional
If the pressures are good, then it does sound like an electrical problem. Have you tested the harness to see if the connector is powered when the A/C is switched on?
Old Apr 28, 2009 | 10:07 AM
96AccordMD's Avatar
I would check the AC thermostat if it has one. My 96 V6 had the same problem and it was the thermostat located in the evap area.
Old Apr 28, 2009 | 04:26 PM
KidFrost's Avatar
i think you mean evap temp sensor....
there are a few sensors in that circut that would prevent it from cycling on. there is also a compressor clutch relay which is switched on by the ecm.
Old Apr 28, 2009 | 04:52 PM
b18cKoupe's Avatar
It may not go on if the pressure is too high also(overcharged), but you say the pressures were spot on so the "thermostat" on the evap may be a good pace to start or a clogged expansion valve.
Old Apr 28, 2009 | 09:05 PM
dtapia's Avatar
what are you static pressure reading high and low side,also readings while the system is on.
Old Apr 30, 2009 | 10:17 AM
Wow, there's been a lot of work on this problem while I was gone. Last night was the first time this week I've had the chance to work on the problem. After checking everything, it turns out that the cooling fan was blowing it's fuse which wouldn't let the compressor engage. I can't believe I missed that blown fuse the first time through...I changed the high pressure switch, the dryer and the underhood fuse box. It works now, but the fix was easy...just the condenser fan is all that needed changing out. Thanks for all the help, I'm sure I'll be back when I do the 6 speed swap :D
Old Apr 30, 2009 | 05:22 PM
dtapia's Avatar
glad it worked out for you.
tutz724
Honda Civic (2001 - 2005)
17
Jan 21, 2019 02:20 AM
4doorcivic16
May 14, 2010 04:39 PM
bopbop93030
Sep 3, 2009 11:10 AM
suzuki1211
May 11, 2009 02:21 AM
Trey
Jul 14, 2003 08:58 AM
