99 4cyl accord with terrible shaking,banging and wobble. Please help
New here name is John.
I need some help.
99 Accord f23a1 5 spd
Bad front end shaking wobbling and loud banging on acceleration at first then over time now it always does it neutral or notand many parts have been changed so far:
Left CV axel right one seemed to be ok
New struts
All new mounts.
New front tires
Also swapped the rear wheels to the front.
Driving me insane and it's extremely bad and doesn't feel safe.
550$ into this and no one can seem to figure it out.
I would seriously appreciate some feedback
Ball joints and to rods are ok also the bearings have zero movement
I need some help.
New struts
All new mounts.
New front tires
Re: 99 4cyl accord with terrible shaking,banging and wobble. Please help
Did you check the passenger side engine cradle?
Mine is rotted completely out, im looking for info on replaceing it...
I have a 97 and I have went thru 4 ball joints couple CV axles. Changed rotors and brakes control arms upper and lower ones new tie rods and bushings on the front end yet, I'm still getting a terrible shimmy when I brake and going on the freeway some things not right..so any suggestions would be great
Unload the front suspension and tip the wheels around, feel behind with your hand at all the suspension points. Replace as necessary.
From the outside watch the engine movement against the held foot brake. Inspect the loose mounts.
Felt vibration braking on highway could be brake rotors have warped.
RichieHHix62
02-05-2018 12:55 PM
