Door Lock Making Funny Noise!!
Old 11-24-2006, 03:02 PM
bitbycarbug's Avatar
Default Door Lock Making Funny Noise!!
Car: 94 Accord 160k, coupe Keyless entry, alarm
I just fixed my driver door cos it wouldn't want to lock but another problem still perisits. When i lock the doors, either from the door or from my keychain, the passenger side door makes a scheeching sound coming from the acuator area. Sometimes it makes the noise once, sometimes 3 or 4 times. The door still locks right away but the noise will continue for 3-4 seconds after its locked. Should I get another actuator to see if that solves the noise.? Totoally lost on this one so if anyone could help thanks.
Old 11-24-2006, 03:09 PM
Tech-Nics's Avatar
is it a LOUD sound or a sligtly low sound, cause my 97 coupe makes a slight sound when the doors lock wheather i lock the doors from the inside and out. sounds like it could be the motor and its normal.
Old 11-24-2006, 03:44 PM
Default Re: (Tech-Nics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tech-Nics &raquo;</TD></TR><TR><TD CLASS="quote">is it a LOUD sound or a sligtly low sound, cause my 97 coupe makes a slight sound when the doors lock wheather i lock the doors from the inside and out. sounds like it could be the motor and its normal. </TD></TR></TABLE>
No, its LOUD and it aint normal I can tell you that. My driver door does make a small sound and I know thats normal but this is loud and doesnt sound good. Great if anyone can help. Im thinking about just putting a new actuator in.
Old 11-24-2006, 03:56 PM
PnX-R's Avatar
Default Re: Door Lock Making Funny Noise!! (bitbycarbug)
I've heard door lock actuators make such schreeching noises when they're starting to go bad. I'd try my luck with a new actuator first.
Old 11-24-2006, 04:14 PM
Default Re: Door Lock Making Funny Noise!! (PnX-R)
Any suggestions about where to get replacement actuators? OEM or aftermarket? Thanks for the replies guys!
Old 11-24-2006, 05:00 PM
hondadude's Avatar
When you get it out, take it apart and you'll see the retaining tab for the spring is broken loose. Cut a shim of some type to put between the plastic tab and the housing; epoxy it in place; then put it back together after the epoxy sets up.
spky
08-12-2010 05:13 PM
MrPscott
04-09-2009 06:47 PM
loup05
05-22-2006 08:47 PM
ThisLittleSleepeR
11-15-2004 09:40 PM
aznazzman
10-23-2003 09:35 PM
Quick Reply: Door Lock Making Funny Noise!!
