97 accord cold air
97 accord cold air
hi i'm new to honda-tech, i installed a cold air intake on my accord and was wondering if they make the car harder on fuel or if i just have another problem
Re: 97 accord cold air
I think the only way it would hurt your fuel efficiency is if the filter is too far gone. It's probably something else. What kind of mileage are you getting?
maybe since you installed the cold air intake you are on the throttle more than usual to enjoy the noise...
i just noticed the rear o2 sensor plug is broke so it's not hooked up, but doesn't that sensor just tell you when the cats bad?
Is your check engine light on? If so, you might be in limp mode, which drastically reduces your gas mileage. Fix the sensor plug and reset the computer.
Do you know what code it was throwing? And having a cold air will not make your mileage worse, it might actually improve it. When I put my AEM short ram I felt a slight increases in MPGs with the same driving style.
sorry i didn't get back sooner, it was throwing code 63, secondary o2 sensor, got it wired up right and engine light off thanks for the help guys
I know this from experience.
blackmagic08
01-25-2005 11:51 AM
SofireGuy
01-05-2005 09:39 PM
