97 accord automatic NO REVERSE GEAR?
Old Jan 23, 2014 | 04:19 PM
evan221's Avatar
Default 97 accord automatic NO REVERSE GEAR?
i have a 97 accord se that has no reverse does not move at all. the car drives fine in the rest of the gears.
when you put the car in reverse {kinda hard to explain} but it makes a whining zipper kinda noise.also if you give it gas the noise just gets louder.
Old Jan 23, 2014 | 04:25 PM
evan221's Avatar
Default Re: 97 accord automatic NO REVERSE GEAR?
fyi: theres no flashing gear lights and ive scanned the car and have zero codes
Old Jan 23, 2014 | 08:11 PM
MAD_MIKE's Avatar
MM Gruppe B
Possibly a problem with the reverse circuit or idler gear mechanism.
Could check the shift solenoids, verify each one clicks and that the screens are not clogged, but this sounds more like an internal problem.
There is a pressure test port next to the shift solenoids, if you have a high pressure oil gauge you could see what the pressure is.
Old Jan 23, 2014 | 08:15 PM
engineerings's Avatar
It may be gear box problem you need to check with trunk....
Digitalis
Jun 30, 2018 09:54 PM
Jordan Jones
Feb 1, 2016 10:38 AM
urajim
Oct 10, 2012 08:00 AM
hatzipri90accord
Apr 1, 2011 12:10 AM
vvebuckeye
Aug 12, 2007 08:01 AM
