02 honda accord 2.3
Old 06-08-2013, 10:52 AM
wade9233's Avatar
Default 02 honda accord 2.3
Im having a knock sensor code and I've already changed the sensor. The check engine light came on again same code what should i start to check next on the car?
Old 06-08-2013, 12:59 PM
ReaperMan's Avatar
Default Re: 02 honda accord 2.3
wiring
ReaperMan's Avatar
make sure connector is clean
Old 06-09-2013, 08:06 AM
Lost Again's Avatar
Let me guess, you broke it changing the starter and replaced it with an aftermarket sensor?
Old 06-10-2013, 07:00 AM
wade9233's Avatar
I did change it with an aftermarket is this my problem? But if not what elese should i do its driving me nuts
Old 06-12-2013, 02:22 PM
Lost Again's Avatar
Can you give the whole story. Was the one in there put in because of a code? Or was the old one working and something else happened to the sensor forcing you to replace it.
Old 06-12-2013, 05:52 PM
wade9233's Avatar
I just recently put a Japan motor in the car all went well except when plugging in the knock sensor it got broke and i changed the sensor off my other motor and everything was fine for 100 or so miles and then i put the new one and it was good about 10 miles then the light was back on again that's when i came to guys for advice on what i should do next
Old 06-12-2013, 10:54 PM
bairdandrew77's Avatar
Maybe it's actually sensing a knock?
Old 06-15-2013, 04:17 AM
Lost Again's Avatar
If you have the other one, put it back in there. I've heard of people having issues with aftermarket sensors.....I know, the dealer wants ~$130 for one.
accordlx5speed
09-10-2014 05:27 PM
wade9233
06-14-2013 06:20 AM
spag
09-13-2006 04:07 PM
9deuce9rr
05-16-2005 08:40 PM
calgone47
10-06-2004 11:46 AM
Quick Reply: 02 honda accord 2.3
