accord 5th gen v4 - v6 front brake switch
accord 5th gen 4cyl - v6 front brake switch
I know this exists in another forum and I do not like to repeat what others have said, but I cannot locate the thread. If someone could point me in the right direction, or those who would like to comment about the procedure, it would be greatly apreciated. Also those who are interested in swapping the rear to disc, feel free to ask me questions cause I am in the process of doing so and have figured out a few things that may stump ya.
Modified by tasurfdude at 10:39 AM 5/22/2006
H-T Order of Merit
Re: accord 5th gen v4 - v6 front brake switch (tasurfdude)
v4, wow, what motor is that? J/K Anyway...
Yes, this has been cover many times. The are different ways of doing this as well. You can use the V6 rotors and calipers, you can use V6 rotors and Legend dual-piston calipers, you can even do a rotor-over-hub conversion. But instead of getting into all that, I'll just post up some links that discuss brake upgrades for both the front and rear of the 90-97 Accords.
V-6 front brakes on a '95 4cyl
95 Accord Legend 2 Piston Brake Upgrade
5th Gen 5 Lug Swap and Brake Upgrade
Rotor-Over-Hub Conversion Revisited
Front rotor-over-hub conversion
4th gen rear disc brakes [Complete]
Rear Drum to Disc Conversion [In Progress]
SUSP: rear disc conversion
