94 accord wont start
Car ran great last night. Came home shut car off went back out and car cranks but wont start. Sprayed starting fluid in it and it fires right up runs a minute and shuts off. The main relay clicks evrytime key is turned on but cant hear fuel pump run....checked ignition and all wires have power, checked fuel pump fuse and its getting power...any ideas?????
Re: 94 accord wont start
If theres a way to jump the relay, and supply 12V to the fuel pump(Would need a diagram) then you could hear it, if not, then I would check the connections at the pump. See if there is power there. Or get a known good relay and try it.
tried a the relay outta my 96 that i know is good and still nuthin. anybody know the colors i need to test in the plug in trunk? jus tryin to eliminate everything before having to drop the tank
pullingin
10-28-2016 02:56 AM
casper.hughes
03-23-2009 08:45 AM
raylightt
09-07-2008 08:14 PM
