92 Accord Tranni problem code 7
Old May 6, 2005 | 08:03 AM
krzyaccord's Avatar
Default 92 Accord Tranni problem code 7
One of my friends is having a problem with his accord, it is always stuck in 3rd gear. I've already checked the Tcm its okay. It is flashing a code 7 could anybody tell me what that is. I've already searched. Tia.
Old May 6, 2005 | 10:28 AM
deserthonda's Avatar
CODE 7 IS A PROBLEM WITH THE SHIFT CONTROL SOLENOID VALVE SYSTEM,,
make sure the wiring are ok and properly plugged ion,, if ok, remove solenoid valve, the lower ones the top ones is for the lock up control...clean the metal screen sometimes they get clugged up thus throw a code 7 ..if you have access to compressed air blow the passages. put back together clear computer twest drive and hopefully for your sake that is all it was oh 1 more thing take a look at fluid make sure it is clean if in question replace fluid
robw13
May 18, 2019 05:45 PM
larryw1945
Sep 30, 2013 11:21 AM
Atomic646
Dec 16, 2012 08:05 PM
Brandong
Dec 4, 2012 05:08 AM
