92 accord problem
Old Sep 29, 2005 | 07:56 PM
wishgiver7's Avatar
Default 92 accord problem
my friends car will not start in the heat of the day, but it will crank right up at night/cooler weather. what is the problem, what part is bad??? thanks!
Old Sep 29, 2005 | 08:21 PM
wishgiver7's Avatar
anybody???
Old Sep 29, 2005 | 08:22 PM
BLKFLSH's Avatar
Default Re: 92 accord problem (wishgiver7)
prolly main relay.
Old Sep 29, 2005 | 08:38 PM
wishgiver7's Avatar
can u please elaborate further? part #, where to get it other than honda, etc etc. thanks
Old Sep 29, 2005 | 10:01 PM
i_kick_turtles's Avatar
There is no knock sensor in his car. It's your main relay, ill bet my left nut. Its in the dash, left of the steering wheel. its a $50 part you can change it yourself, buy a manual they help a lot.
Old Sep 30, 2005 | 09:35 AM
LOGICx420x's Avatar
If your friends car is not starting in the heat of the day its gonna be you main relay and sorry to say you can't just get it from any autoparts store. It's a dealership item. It cost me $70. I also don't recommend getting one from the junkyard unless you going to get for testing purposes. You are much better off getting a new one...
Old Sep 30, 2005 | 02:42 PM
Default Re: 92 accord problem (LOGICx420x)
there's been some on ebay for a lot less lately, check it out.
Old Sep 30, 2005 | 07:51 PM
deserthonda's Avatar
when car does not start. remove the tube going to the throttle body, spray some carb cleaner in there , if car starts up . remove the main relay and inspect for cracked solderings ,,if you see any , resolder them ,, no need to spend money on a new relay ,,you do however need a soldering iron
seanblais
Jul 31, 2013 12:15 AM
vshc82870910
Jun 21, 2010 11:28 AM
BrodyH
Aug 7, 2005 08:57 PM
jacobpel
Jul 28, 2004 03:01 PM
Coreyja
Sep 3, 2002 10:03 PM
