1999 Accord power locks - need help
Old 08-26-2009, 07:26 AM
dmeconitas's Avatar
Icon2 1999 Accord power locks - need help
My wife has a 1999 honda accord lx and all four power locks do not work. I highly doubt that all four actuators went out all at the same time. They cost a pretty penny too 100 bucks a pop. I checked all the fuses and they are good. However when you push the lock or unlock you can hear a clicking noise come from the passenger side fuse box, like a switch is being tripped or something. The locks sound like they want to work. Any help will be appreciate. I did search and found out ways to repair the actuators if they are bad but I dont think that is the problem. Thanks in advance.
Old 08-27-2009, 06:28 AM
dmeconitas's Avatar
Default Re: 1999 Accord power locks - need help
bump
Old 08-27-2009, 09:53 AM
Heat's Avatar
Touch the locks as you try to lock / unlock them, see if they "jiggle". If so, I'm in the same boat.
I just lock / unlock the doors manually at this point, though when I unlock the passenger side the driver's side has enough juice to unlock (but not vice versa).
Old 08-27-2009, 12:35 PM
3zFree's Avatar
The actuators are common to go out on that year/model. Had to get all 4 replaced on my 99 accord, not all at same time though. And the actuators are not $100 each, I just finished doing 3 of those on friends accord and the ones for rear were like $35 and front are $40 or something similar. Look around at honda online parts stores. Rears take about 15 minutes to do each, but the fronts are a little tricky.
Old 08-27-2009, 02:25 PM
Janet@bisimoto's Avatar
+1.
Old 08-27-2009, 04:33 PM
dmeconitas's Avatar
But if it was the actuators whats up with the clicking noise by the fuse box? It reminds me of when a circuit breaker. Does anyone know if there is one under there?
Old 04-23-2010, 11:34 AM
mdrussell24's Avatar
Did you ever figure this out on your locks? I have the same problem - remote quit working, and the locks make a sound when I hit the button inside and sometimes they move a little but that's it. Luckily I haven't locked my keys in...yet. lol
Old 04-23-2010, 11:40 AM
dmeconitas's Avatar
naw I have not figured it out yet. I have not gotten around to purchasing actuators to see if that indeed is the case. Let me know if you figure yours out.
Old 04-23-2010, 11:51 AM
RICKSAUTOMOTIVE's Avatar
sounds like a relay is bad. (the clicking)
Old 04-23-2010, 11:55 AM
also check your door lock control unit.
hfbellosa
10-07-2013 04:27 PM
Tris320
12-19-2007 08:48 AM
ny153
10-23-2006 06:29 PM
kniob
09-03-2006 03:16 PM
Quick Reply: 1999 Accord power locks - need help
