1998 clutch
Old Jun 17, 2006 | 03:12 PM
moabiker31's Avatar
Default 1998 clutch
1998 Accord Ex 5sp 4cyl 170,000 miles
The clutch feels limp and when fully pressed to the floor the car continues to go forward and is difficult to get out of gear. I've read a couple other posts that have suggested to check the clutch master cylinder but I'm having trouble finding it. Is it next to the brake master cylinder near the back (closest to the windshield) of the engine compartment? If it is, there's plenty of fluid in there. What would be the next thing to check/replace? Is this a job for the weekend mechanic? How long would it take? I have a Haynes manual and am fairly good at following directions but I'd rather not spend an entire weekend doing this to find out it's too big of a job for me. Any advice is appreciated. Thanks.
Old Jun 17, 2006 | 03:24 PM
-RedneckDave-'s Avatar
Working
Default Re: 1998 clutch (moabiker31)
Bleed the clutch system.
Old Jun 17, 2006 | 09:16 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: 1998 clutch (-RedneckDave-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -RedneckDave- &raquo;</TD></TR><TR><TD CLASS="quote">Bleed the clutch system.</TD></TR></TABLE>
Yup what he said.
Also check and makse sure you don't have any leaks or problems with the line, master and slave sylinder.
Old Jun 19, 2006 | 06:56 PM
moabiker31's Avatar
Default Re: 1998 clutch (-Bionic-)
thanks for the suggestions. I bled the system. Didn't find any air pockets. Same problem is occuring. I'll look a little closer for any leaks.
Old Jun 19, 2006 | 07:12 PM
98_accord_ex_'s Avatar
I change my last summer master and slave , took me about an hour or 2 to put the master and bleed the clutch... I was not in a rush, it only to bolt and 2 clip.... the worst part is to put the clip that hold the pipe in place and make sure you get the o-ring, cost about 20$ cnd to have a new one
Old Jun 21, 2006 | 07:39 PM
moabiker31's Avatar
Default Re: 1998 clutch (98_accord_ex_)
There might be a small leak coming from the master. I plan on replacing it. Why do prices vary so much for the master cylinder?
$16.07 - http://www.hondaautomotiveparts.com
$83.95 - http://www.secureleadercom.com - also includes mounting gasket
$15.45 - http://magauto.com
$30.00 - at local dealer
$60.00 - at local parts store
Any idea if these include other items besides the master cylinder such as the o-rings, gaskets, etc. The Haynes manual says to use new o-rings so I want to be sure they're included or order them separately. Thanks.
jlowellintegra
Nov 27, 2010 08:15 PM
FRKWOO
Apr 5, 2009 03:58 AM
noy612
Jun 11, 2008 06:04 PM
cleanej2
18
Feb 1, 2008 11:42 AM
budget
Mar 30, 2005 02:25 PM
