1997 steering wheel colimn
I recently had a mechanic put in rebuilt Rack and Pinion.
The mechanic did a good job installing the Rack and Pinion
But not a such good centering the Rack and Pinion before he put on the outer tie rods.
I went over he said he moved the steering by adjusting it at the column.
If the steering is unhooked at the bottom where you attach the yoke to the rack and pinnion can I the clock on with the yellow dot to fix this i know i would have to unhook both outer tie rods.
I am convinced the rack was never centered we got both wheels with in 1/8 of a inch but there no more adjustment..
The good news the rack does not leak
starbai
Suspension & Brakes
01-05-2010 04:23 PM
