piston swap
Old 06-20-2013, 10:37 AM
3rdgenF22_lude's Avatar
Default piston swap
anyone ever put g25a4 pistons in an f22? i cant find anything on this anywhere....
Old 06-20-2013, 10:52 AM
Shmallow's Avatar
Default Re: piston swap
why would you? what would be the benefit?
would they even fit? the bore is the same but what about the wrist pin diameter and compression height?
i don't think the design/dome size is significantly different from stock F22 pistons. i would speculate that if they drop in without modification or clearance issues then the effects would be somewhere between insignificant and nothing.
Old 06-20-2013, 09:42 PM
Wrist pin is same bore and g25 has comp ratio of 9.6:1 i cant find spec on comp height tho
black D
Honda Civic (2001 - 2005)
05-17-2011 12:28 PM
ekVtecPower
07-25-2006 05:42 PM
high_revs
06-17-2005 09:40 AM
93H22ACX
05-18-2004 04:55 PM
Teal95Coupe
08-17-2003 05:12 PM
Quick Reply: piston swap
