1994 Honda Accord LX CRANKS BUT NO START
Replaced the distributor, fuel pump relay, ignition switch and replaced main computer. The car starts at times but has a mind of its own meaning it might not crank for a day or two. Sometime you can hear the fuel pump when you crank and at times no fuel pump noise.
I have replaced everything but the fuel pump.
Any suggestions???
Any suggestions???
Re: 1994 Honda Accord LX CRANKS BUT NO START
multimeter the fuel pump wire harness when cranking/key in start position, and see if it gets power. if it gets power it should be priming.
Go to harbor freight and buy a fuel pressure tester kit for $20 and hook it up and lay the hood gently down on the gauge with it facing the driver in the windshield. Keep an eye on fuel pressure and see if it's dropping off when the car isn't starting or when it's dying.
You can even just turn the ignition to on and turn it off and do a dirty test buy cracking open the fuel pressure banjo bolt just to see if it's getting fuel.
Mr Frustrated
06-20-2017 03:21 PM
pentagon
12-30-2009 10:39 PM
4doorcivic9
06-11-2008 06:31 AM
