1992 accord ex auto tranny hard to get out of park 104k
Old 04-23-2008, 11:56 AM
Hondapreludeg's Avatar
Default 1992 accord ex auto tranny hard to get out of park 104k
I have a 1992 accord ex and it is really hard to put into park and to take it out. I have to pull it out with both hands sometimes. It has only 104k on it. Tranny shifts hard sometimes but I have heard these trannys arent that great. Any ideas? Thanks in advance
Old 04-23-2008, 04:17 PM
hondadude's Avatar
Default Re: 1992 accord ex auto tranny hard to get out of park 104k (Hondapreludeg)
When you remove the center console you'll be able to check the shift interlock solenoid to be sure it is moving all the way, when you step on the brake.
You'll also be able to see the interlock and the adjustments.
FYI; The 90-97 Accord auto trans are the best Honda has made; They DO shift under positive pressure, not that GM MUSH shift.
Old 04-23-2008, 04:37 PM
bseriescrxsi's Avatar
Default Re: 1992 accord ex auto tranny hard to get out of park 104k (hondadude)
i had the same problem and the problem wasnt in the shift interlock solenoid...what i did was got under the car and opened up the cable housing on the tranny and sprayed some pb blaster in there while having someone move it slightly.....it solved the problem on mine....good luck
Old 04-24-2008, 08:15 PM
tracy7293's Avatar
the best thing to do is just replace the shift cable!! i had the same problem with mine and that was after i had replaced the tranny. i had to use both hands to pull mine out of park also! thought it was no big deal at first,then.....IT BROKE!!! word of advice, just replace it.
Old 04-25-2008, 09:07 AM
lubed it up and now its good thanks guys!
00Accord03Odyssey
01-22-2009 06:30 PM
Ihatecars
07-24-2006 02:22 PM
djdestruction
11-15-2005 03:08 PM
cyrixvsp2
12-20-2002 09:29 AM
H23 Power
01-30-2002 04:10 PM
Quick Reply: 1992 accord ex auto tranny hard to get out of park 104k
