1991 Honda Accord LX won't shift after accident
Old 01-21-2010, 11:59 AM
Uneek One's Avatar
Icon6 1991 Honda Accord LX won't shift after accident
Recently got in an accident that "totaled" the car according to my insurance. I know it may be fixable and cheaper than buying a new accord, so I want to see if its possible to fix.
I got in a front end accident that smashed in my hood and radiator. Everything from when i look inside the engine appears untouched. The only part that seems messed up is the upper radiator hose, radiator, bracket, and things that were in front of the radiator.
My driver side light is also broken and the bumper completely came off (the plastic part not the hard one under it. that has a tiny gash on it and that's all.)
So so far I know I need a
New hood (or fix the bent one)
Bracket
Radiator
Radiator hoses
Things attached to radiator? (may come with radiator...they looked like pipes)
But my dilemma is...I don't know why my car won't shift out of park unless I insert my key in the shift lock thing. It refuses to shift on its own. And the car will not start. Everything powers on but it does not actually start. I have a feeling this may be an older issue where my battery cables are becoming old worn and dirty, so they're not properly emitting enough power for the car to start.
I attached an image so you can visually see the damage.
I don't even have a garage to part it in, so I can't get the value that I want for it. So I figure fix it up to a drivable condition, sell it for more than $145 (junk yards quotes). I just got the darn water pump and drive belts done the week before. My mechanic said the engine was definitely still good but he didn't want to start working on it unless he knew I had at least $3200 to fix it up with, Now I think he said $3200 because he doesn't want to bother with it. He has so many cars in his lot, it'd take at least 2 months before he could get to mine and actually take care of it. So I think that was his way of "go find someone else" without really trying to loose me as a customer.
Please help
Oh and another thing to note. Nothing on my dashboard is blinking or lights up other than the normal backlight.
Old 01-21-2010, 04:13 PM
cctgene's Avatar
Default Re: 1991 Honda Accord LX won't shift after accident
Check your axles, maybe one of them popped out of the transmission.
Old 01-21-2010, 04:37 PM
Uneek One's Avatar
Any idea how many hours that takes or how much it'd be?
Old 01-21-2010, 11:48 PM
cctgene's Avatar
You should be able to tell if an axle popped out by just looking at it from underneath the car. There will be a noticeable gap at the point where the axle is inserted into the transmission. What it would cost to fix, if indeed this is your problem, is hard to say because you may have other damaged or bent components as well. However, if its just a popped axle you may be able to fix it by just pushing it back in or by replacing the axle itself. I think a rebuilt axle for your car is around +/- $60 dollars or so.
Old 01-22-2010, 09:33 AM
Uneek One's Avatar
Thanks that was really helpful I'll go look under the car today but it probably was that or something maybe around there because I was pretty sure I saw tranny fluid leaking from the car after the accident.
sam000lee
06-13-2015 06:20 AM
93Accord_4_ever
11-11-2010 08:49 AM
wdissident
Welding / Fabrication
02-18-2009 07:05 PM
jjd85262
08-29-2004 03:41 PM
Quick Reply: 1991 Honda Accord LX won't shift after accident
