1990 accord Help
Old 05-12-2011, 10:49 AM
cellblock's Avatar
Icon2 1990 accord Help
I have a 1990 honda accord and after the car sits for a couple of days it wont start But after cranking on it for a few times then let it sit for a hour it will start up .... Helppppppp
Old 05-12-2011, 05:38 PM
JamesB1985's Avatar
Default Re: 1990 accord Help
Definitely get to the main relay and find out if its operating correctly.
Old 05-12-2011, 07:10 PM
specialone70's Avatar
im thinking something with the fuel lines or pump. maybe a leak? i had a friend that had to crank his engine for a while because the fuel would run back down the line after it sat a while because the pump wasnt keeping the line closed.
thats my best guess, i hope it helps!
Old 05-13-2011, 02:11 PM
cellblock's Avatar
I put a new fuel pump on a week ago ...still does the same thing.... But have had a smell of gas sometimes while car is at idle , maybe it is leaking off ...what would the main relay do?
Old 05-14-2011, 12:07 PM
navcc's Avatar
Hi, the main relay operates the fuel pump. your best bet is to take out the main relay out and open it. using a magnifying glass look out for any hair line crack in the solder, if any crack found, resolder it. your main relay should work fine. the relay is located below the dashboard, driver's side. It's a fairly easy job to do. Good luck.
M4-2000-08
08-18-2012 04:16 PM
NorthCountry
07-13-2011 01:38 PM
dmc3262
04-11-2011 11:35 PM
thiendegigolo
07-23-2010 05:38 AM
nonbox
01-30-2006 01:00 PM
Quick Reply: 1990 accord Help
