SRS light on all the time, '02 accord EX V6
Old 08-11-2006, 01:16 PM
Tim 95 M3's Avatar
Default SRS light on all the time, '02 accord EX V6
It was intermittent before, but now when starting the car the light permanently stays on. What are the common causes of this?
Thanks - tim
Old 08-11-2006, 05:20 PM
hondadude's Avatar
Default Re: SRS light on all the time, '02 accord EX V6 (Tim 95 M3)
Could be the control unit, you might check for recalls . the other common problem is the clockspring under the steering wheel. it would be way cool to know what code is stored in the control unit
Old 08-12-2006, 11:36 AM
Tim 95 M3's Avatar
Default Re: SRS light on all the time, '02 accord EX V6 (hondadude)
anywhere I can check for recalls, that won't cost money to look them up? I have looked around and can't find anything. Also, the car is out of warranty... so will they repair a faulty SRS component on a 2002 car with 110k miles? Not for free, I assume, but are discounts on items like this common if it's a common problem? I've mainly dealt with BMWs, where the dealership generally tells people to go F themselves, lol. Thanks in advance,
-tim
Modified by Tim 95 M3 at 3:59 PM 8/12/2006
Old 08-12-2006, 03:07 PM
Tim 95 M3's Avatar
after more searching i found a good website for recalls/TSBs... http://www.carcomplaints.com , hope you guys like it.
Old 08-12-2006, 03:18 PM
ryanstix's Avatar
Question bout a clutch problem. Just replaced the master cylinder and the clutch is just staying pressed to the floor because I cant get any pressure in the line what should I do?
Old 08-12-2006, 03:20 PM
ryanstix's Avatar
Default Re: SRS light on all the time, '02 accord EX V6 (ryanstix)
the honda with clutch problem is a 97
Cjkaz
06-18-2018 04:24 PM
Slo-STI
11-11-2011 06:05 PM
stevescivic
05-15-2009 10:35 PM
moddhu
09-13-2008 05:24 PM
03trmn8r
12-11-2005 11:38 AM
Quick Reply: SRS light on all the time, '02 accord EX V6
