03 Accord EX V-6 Orange Triangle light on?
I have 03 Accord with the Orange triangle light on always with no other lights on. However I have noticed the TCS red light come on and stay on until the car is shut off while driving. I tried searching but couldnt find anything as most people have the E-brake light on also which I do NOT. Brake fluid level is good, No CEL, I have tried disconnecting the battery and reconnecting it. Could it be the ABS module or are there senors on the wheels that I can check?
Thanks in Advance
Thanks in Advance
Re: 03 Accord EX V-6 Orange Triangle light on?
I have an 03 coupe v6 too. Love it. The orange triangle is traction control. When it stays on. Means you have traction control turned off. Its a button on your left next to steering wheel under then air vent marks TCS. Just press it. And traction control will turn on. Turning the light off. Or something of another. If the car is slowing down till you shut it off. Its your tire pressure. Its just low. If all things check out- tire pressure, traction control on. Then gonna have to get it fixed.
Or its a button labeled. VSA. Aomthing like that
class im too lazy to walk out to my car. Either way. It wont harm your car.most likely you have bas sensors
moddhu
09-13-2008 05:24 PM
