Quick Sway bar question
Old 07-07-2009, 04:27 AM
kccord's Avatar
Default Quick Sway bar question
Hi guys, I didn't get a chance measuring the size of my rear sway bar, as you know it is in workshop now and I'm keen on upgrading suspension b4 turboing.
a. Can anybody tell what the oem's CD5 rear sway bar diameter is??
I'm looking at Whiteline sway bar sourced locally, the diameter is 18mm and comes with polyurethane bushing for $210AUD shipped!!
b. Is Rear 18mm good enough??
P.S. Progress Sway bar is on back order for few weeks, and other's are too expensive from US + shipping kills for item with that size. TIA
Old 07-07-2009, 09:11 AM
Bwill9886's Avatar
Default Re: Quick Sway bar question
You will feel a difference, however 18mm is smaller than some of the other sway bars offered.
My Addco is around 22mm and performs very well. Keeps the rear pretty planted. Had to change the bushings which were supposed to be polyurethane but definitely were not. Other than that, good stuff.
Old 07-07-2009, 11:26 AM
BBallz24's Avatar
Sway Bar Diameters (mm)
FRONT
OEM - 27
Tanabe - 30
Suspension Techniques 27
REAR
OEM - 15
Tanabe - 20
Progess - 22
Suspension Techniques - 21
Old 07-07-2009, 11:34 AM
He knows where you live!
TheMuffinMan's Avatar
Good enough for what? What are your goals? A sway doesn't do much if you just want straight lines.
Old 07-07-2009, 02:41 PM
kccord's Avatar
DD and once a month track day or strip days.
FRONT
OEM - 27
Tanabe - 30
REAR
OEM - 15
Tanabe - 20
Progess - 22
Thanks for that info yo!!
Old 07-07-2009, 03:15 PM
ST or the one you found should be sufficient
grandtheftlunchbox
23
11-04-2008 08:06 PM
zippo1130
15
01-15-2008 07:45 PM
CALC!_JUST_du_IT!
07-25-2007 06:30 PM
lowbOOsted
12-05-2005 05:37 AM
gubo22
09-03-2003 12:57 AM
Quick Reply: Quick Sway bar question
